Carrier central air unit is shaking and broke a fan blade off inside the unit
  • 252 Answers
TURN IT OFF! You're gonna need a new fan blade! Motor MAY be ok, and hopefully nothing was damaged by the flying blade. Just happens but not often - you're just lucky.
Posted on Sep 08, 2009
My Carrier Central Air unit is not working and shows Code: 24 VAC power
Will the indoor unit run with the Thermostat fan switch set on auto?
I need to confirm that the indoor unit runs first.
Jun 03, 2014 | Carrier 38CKC036 Air Conditioner
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
I HAVE A CARRIER CENTRAL AIR, THE OUTSIDE FAN IS BLOWING INWARD AND WON'T SHUT OFF WHEN THE FURNACE SHUTS OFF AFTER TEMP IS REACHED
Check the t-stat to make sure that the "fan" switch is st to auto. If not the fan is in the "on" position and is always on. Otherwise, It sounds like your "Central Air" is a packaged unit(Furnace and air all one unit outside the home) and the fan relay inside the unit is stuck. This need to be replaced. It is the rectangular unit with the leads from the fan motor attached to it.
Jul 29, 2011 | Heating & Cooling
The fan on my Carrier central air conditioner a/c model 38ER036300 does not move when the compressor kicks on. The unit will heat up and then will start. It also will start when I give it a small push. The...
Hello YES the blades have to move freely.If it has oil ports look on the side of the motor for a YELLOW plastic plug/cap there are 2 one at the top & one at the bottom.Pry them off/loosen with a small screwdriver & squirt #20 oil in the holes.3 in one oil will work also.If there are no plugs it is factory sealed & it is new motor time.
Aug 28, 2010 | Carrier 38BRC060 Air Conditioner
I have a carrier window unit that lost a fan blade
you can by a fan blade. any refgriation parts store can get you one or you can get the model number and order one off the internet.
Jun 30, 2010 | Carrier BCA101R Air Conditioner
I have a central heating and air unit. The unit
sunds like the fan bearings have seized up or u have a bad fan capacitor take a screwdriver and spin ith blade to where the air would be coming out the top and if it startswhen u spin it u need a fan capacitor
Feb 23, 2010 | Coleman Propane Forced Air Heater...
Fan wont turn off
the control board is bad safety feature of carrier board . Tom
Jun 29, 2009 | Carrier 38CKC042 Air Conditioner
Carrier central ac high efficiency
usually capacitor,burnt wires or bad compressor.kill the power and check the terminals at the compressor.they have been known to burn off if the connection is loose.
Sep 06, 2008 | Carrier 38CKC042 Air Conditioner
Central air conditoner unit doesnt blow cool air into home has some ice on the inlet heat and cooling lines going into the central air unit
Change the furnace filter. Make sure you use a cheap one when air conditioning, as the better ones restrict airflow when they filter out so much stuff and then plug up, not allowing enough air to pass over the cooling coil in the furnace's air plenum. Turn the A/C off for a few hours (with only the furnace fan on if possible) to melt the ice off the cooling unit inside the furnace.
Sep 01, 2008 | Carrier Heating & Cooling
Carrier fan unit
Poke the fan blade with a stick to see if the bearings are seized up. If it turns easily, you have an electrical problem, like a bad capacitor.
Jul 20, 2008 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
281 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
