Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I bought my kodak ESP3 all in one printer. I the last 2 ink replacements stopped printing colors as brilliant colors as before and this is barley my 3rd new ink replacement and still no clear colors? What could the problem be?
I have a Kodak esp3 printer. I replaced the color
I have had exactly the same problem. I can't carry enough ink to it. Plus even more perplexing is the fact that it won't print b & w when the colour runs out and visa versa. I havent printed any colour stuff at all since replacing the colour cartridge last month and yet again it has run out. Advice / help siteuseless. If they spent as much effort with helping customers as they do with their useless junkmail then the servic would be better. Best advice steer clear of kodak printers !!!
Jun 02, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
My Kodak printer ESP3 is not printing. It keeps flashing over the 3 color tear drops (red,green,purple). Ive powered it on and off several of times as well as checking the cords.
This 3 color drop flashed when the color ink cartridge needs to be replaced.
Try to use a new color ink cartridge > If no go, call Kodak they will replace the color ink > If no go > Call Kodak and this time they will replace the printer
Jan 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Have kodak esp3 printer said I needed to replace the color printer( which I have never printed before in color only in black) but okay I put in a brand new black AND a color ink cartridge it still is...
I could suggest that you contact Kodak direct as you will need to get a replacement printer. Log onto www.kodak.com and select the help and support tab. Select the online chat option and tell them about this issue.
Oct 23, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
My printer will not print in black and white, as my colour cartridge is low. How can I just print in black ink? Kodak esp3 all-in-one printer.
Believe or not, a bit of color ink is require to make true black. However, from most application you can go in to the printer preferences and click the Color tab. Check the print in Grayscale and click the Black print only option. My instructs are based on an HP model printer. The preferences can be a little different between brands. But, you should have similar options. Check your printer's manual for more specifics.
Oct 03, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP3 installed 2 new cartridges black light
For that problem kindly try doing the ff:
* Re-seat the inks both color and black then try printing
* Re-seat the Printhead of the printer then print again
* if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Sep 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
My printer 3 in one kodak esp3 the ink is full
upgrade the firmware of ur printer.go to kodak.com/go/printhead support.take out printhead and ink cartridges ,reseat them again.if problem still persists,call kodak @ 1800 421 6699. they will replace ur printhead free of cost
Jul 22, 2009 | Kodak 5300 All-in-One InkJet Printer
It only prints light color ive replaced branw new
You need a new print head. Don't buy one, though. Phone Kodak (India) and get a new head. Or throw the stupid machine away. Kodak should be sued for producing such poor quality ****.
Jun 30, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Paper jam
Yes, put it in the box and take it back, and don't look back. A paper jam is the least of it's problems. Wait till you keep track of the ink you use: 4 4X6 color pictures, and 85 black printed pages before you have to replace the inks. I know , I have one, 3 printheads replaced, and recently Kodak send a rebuilt printer. Kodak has big problems with this.
Get an HP printer.
May 25, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Just changed ink everything is purpleish pink esp3 kodak printe
Pink color usually indicates, color cartridge bad,
Try cleaning nozzles, head cleaner, alignment, calibration
Print off a test page,
If still bad, New cartridge, it's a bad one.
Hope this helps
Richard.
Apr 18, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
50 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
