Question about Proficient Audio Players & Recorders
My proficient subwoofer keeps blowing fuses when i plug it in why?
Benimur
  • 6966 Answers
SOURCE: Subwoofer issues
The fuse blows when the current that passes through it are beyond its rating. This could be brought about by excessive consumption of the load, in this case the amplifier powering the sub-woofer.
Repairs would involve component level and require that you be familiar with electronic components and circuitry, use of a DVM and a soldering iron. Often it is just the finals that needs to be replaced. Of course we cannot discount the possibility of other components or section such as the power supply.
The smoke indicates something heating up such as a resistor or diode or a capacitor.
Should you be uncomfortable opening the unit and doing a DIY (do-it-yourself), then perhaps you need to seek the services of a qualified professional.
Should the downtime and cost of repair be no longer economically reasonable, purchase of a new unit might save you further trouble.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 23, 2008
SOURCE: fuse blows
Presuming you're referring to the circuit breaker in your house, it's probably because you have too many items on that circuit. Your best bet would be to find another power outlet that is on a different circuit, and plug some things in over there.
Posted on Jun 19, 2008
  • 26 Answers
SOURCE: fuse on subwoofer keeps blowing
Subwoofers draw a tremendous amount of power. With the amount of heat generated by amperage flow and the movement of the voice coil, you may have burned out the coil. Do a resistance check across the coil. Easy check? Temporarily attach another speaker to replace that one. Use LOW VOLUME and slowly work the vol up,and, if the fuse does not blow, it's the other speaker.
Posted on Mar 10, 2009
  • 10 Answers
SOURCE: blown fuse in mission 700as subwoofer
if you have access to a multimeter, you should test you impedance (ohms) Ω, check to make sure the speakers reads higher than the amplifier needs; this will result in less strain on your amp and diminishement of sound...For example: if you connect two 4Ω
speakers in series it results an 8Ω circuit (least strain). and if you'd take the same two speakers and connect them in parralelle it would result in a 2Ω circuit (most strain).
Posted on Jul 24, 2009
gokomets
  • 120 Answers
SOURCE: Subwoofer keeps blowing fuses.
THE AMPLIFIER "IC" MAY BE SHORTED!
IC MAY NEED REPLACED.
Posted on Apr 10, 2010
Keeps blowing fuses
You need to be very specific about your question. When people see "Glow Plugs" one thinks about Diesel Engines and not Car Audio.
Jan 15, 2014 | Car Audio & Video
Keeps blowing fuses x4 as soon as powered on
Pull the speaker and check the coil with a meter. Should read 8ohms. chances are you have a burnt voice coil. They have a 2 year warranty on subs.
Jan 09, 2011 | Proficient S12 Subwoofer
PS8 Subwoofer started buzzing non-stop
with nothing connected and the sub turned on....Most subs buzz when the circuitry starts to fatigue. The last time I heard this ..the repair ended up being one of the two fat capacitors inside the sub. I have a means of testing this,,you may not. I am a repair shop with a bit of experience in component level board repair.
May 06, 2010 | Proficient S12 Subwoofer
Apr 10, 2010 | KLH ASW10-120 Subwoofer
Powered subwoofer keeps blowing its fuse
The amp is blown. You need to get it in for service. No telling exactlly what is wrong untill it is opened. 215-736-8055
Jan 15, 2010 | Onkyo Bass Reflex Powered Subwoofer...
I have the same problem as described by Fufanuer. I have no power to S12 Subwoofer as it keeps blewing fuses. As I replace the fuse 4a 250V with new one it blew right away. Can anyone help? Hal
I too am looking for the solution, I'm hoping I have the wrong power cord which is sending too much power to the sub, my next attempt will be to just up the AMP on the fuse b.c hey it's broken anyway
Nov 20, 2009 | Proficient S12 Subwoofer
It keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
Fuse
It is below the subwoofer A/C plug and you need to pull it out
Dec 18, 2008 | Proficient S12 Subwoofer
Proficient Subwoofer S12 - No Power
Check the fuse which tends to blow frequently.
Oct 29, 2006 | Proficient S12 Subwoofer
124 people viewed this question
Top Proficient Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Proficient Audio Player and Recorder Expert? Answer questions, earn points and help others
