Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Can't turn of Closed Caption
I have a Sharp Aquos 42" connected to my HD tuner via HDMI cable. The CC won't turn off on either of the HDMI inputs 4 or 5. Suggestions?
  • evianm Dec 10, 2007
    I'm not sure how to check that it's not on auto.
    New Friend:
  • 57 Answers
Check to make sure they are not on auto
Posted on Dec 10, 2007
  • Keith
    Keith Dec 10, 2007
    it could be in section where mute is
CANNOT TURN OFF CLOSED CAPTION ON 52" JVC TV
Does it use a cable box or are you using the tuner in the TV?
If you're using the tuner in the TV, try unplugging it for 5 minutes and then plug it back in, do a new channel scan and see if the CC goes away. If not, contact JVC to find out how to reset it. If it still does not work, you might need to have your main board replaced.
If you're using an external tuner plugged into a video input port (such as a cable box or satellite box) then the external box is at fault since TVs don't have CC available through their composite or component or svideo or hdmi ports.
Jun 19, 2009 | JVC HD-52G787 52" Projection Television
Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp 37'LCD missing Close Caption in Component and HDMI input
I HAVE A SHARP SHARP LC19SB25U - 19" Class HDTV LCD TV. I can turn it on but I have no pictue and cannot use the remote that came with it. For some reason, when I press buttons on television or the remote, it won't respond. Can you help me.
Jul 31, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Closed Caption TV
Check your remote for a button marked SAP or CC.
Jul 08, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Turn off closed caption on input(component) on Sharp Aquos 42"
Had this happen on a Comcast box (Motorola DCT 6416 III)
Here's how to fix it:
Turn the cable box off, leave fully connected. Press Menu on the remote
The cable box internal menu will display (Not the Comcast one the Motorola one-- i.e. Display ratios-16:9 etc It's in black and white)
Use the arrows to cursor to the Closed Captioning and toggle to "Disabled" Press Manu again to exit and Voila!
Power the box on an have at it
Apr 10, 2008 | JVC HD-61Z575 61" Rear Projection...
Sharplc20sh1e
Do you mean the closed captioning or is it the subtitles when viewing a DVD. If it is the DVD then the subtitles need to be turned off on the DVD player. If it is the closed caption and you have a HD Comcast or other type of cable box, then the CC needs to be turned off on that device.
Feb 06, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Jan 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
This is what just worked for me. If I can figure this out, anyone can :) We have comcast cable hddvr box, motorola 3416, and a new Samsung HD Plasma, but try this no matter what you have...
turn your cable box off, and THEN press menu on the box. A white screen popped up and this is where I had to scroll down to and disable the captions. I couldn't believe this worked since I thought the cables were enabled on my TV since my captions were covering my cable menus, but it was the cable. I hope this helps.
Oct 23, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
320 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
