Question about Sony KV-32S25 32" TV
Tv sony kv-32s25, liga vem o som sem imagem e o led fica piscando.
  • 1694 Answers
SOURCE: Sony KV-32S25 32"
Check Horiz. output transistor = shorted?
1)replace with first quality transistor
2)solder horiz driver circuitry
3)replace shorted converter transistors (2SC4834)
4)Replace open R607 .1 ohm 1/2 w.fusible (resistor ok)
   test.......T.
Posted on Oct 26, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
I have your service manual but I can't find any reference to 9 flashes, are you sure it is 9 with out a pause?
see below from manual.....
Posted on Jan 31, 2008
jerryg50
  • 1667 Answers
The relay is in the power supply area. I am sure that the fault is not the relay.
It is very common that there are various components starting to go off spec from age. Most of the failures are in the scan amplifiers and power supply areas.
It is also possible that the CRT emission is too low from age. What happens is that it is on the minimum edge and this explains why the set may turn on some of the time.
When the main uPC in the set sees any potential fault conditions it will go in to a protection mode to prevent damage and to be safe. Your set is probably borderline to operate.
Considering the age of your set, I would be shopping for a new TV set.
Jerry G.
Posted on Jul 12, 2008
daniel719
  • 240 Answers
SOURCE: Sony FD Trinitron WEGA KV-30XBR910 30" TV Led flashing
6 blinks meens no horizontal and no raster check capasitor c515/c516/ jungle IC and IC206.
regards,
daniel.
Posted on Jan 13, 2009
  • 4234 Answers
SOURCE: how can i change ntsc to pal / kv 32s25
Changing this requires a change of the tuner. There is nothing inside the set that can make this change. There are external systems that can do this, but they are expensive (multiple $100s).
Bottom line is that this would require a change in the internals of the set.
Dan
Posted on Mar 16, 2009
ML 1610 no power
tenho essta impressora, samsung ML-1610 e quando liga, ela reinicia mas fica com as duas luzes piscando, uma vermelha e outra verde, o que devo faser pra funcionar normal, o toner ? novo.***.
Digerson.
Apr 26, 2011 | Samsung ML 1610 Laser Printer
I have sony kv-32s25 powers on but no picture i do have sound and the stand by light is flashing and idea's
The key here is the standby light flashing. It should be flashing in a repeated count of flashes with a pause inbetween. Count the blinks and report that number here. This is a diagnostic code indicating the circuit that is having a problem. Armed with that info, we should be able to give you an idea of the problem and its solution.
Thanks,
Dan
Apr 28, 2010 | Sony KV-32S25 32" TV
SONY KV-32S25 TV SHUT OFF...NO POWER NO SOUND
You have a blown fuse. It should be a GMA7 amp or a 5 amp. You could try to replace it and see if your TV works again. If it blows the fuse again, then there is something shorted causing the fuse to blow. Then call a good TV Tech.
Aug 03, 2009 | Televison & Video
How can i change ntsc to pal / kv 32s25
Dan
Mar 16, 2009 | Sony KV-32S25 32" TV
Sony KV-32S25 32"
   test.......T.
Oct 25, 2007 | Sony KV-32S25 32" TV
TV keeps flashing on/off
Is the picture coming and disappearing? Or is it that the TV is switching ON and then OFF? And what about the sound? Please provide more details.
Aug 28, 2006 | Sony KV-32S35 32" TV
Televison & Video Logo
63 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
