Question about Nokia N73 Cellular Phone
I added some sort of adblocker- but I forget which!!
I need to remove some sort of ad blocker that I put on my computer a year ago. I forget which one it was!! When I go to any ad and click it it gives me an... Oops! This link appears to be broken. Please help me fix!
Thanks.
  • 1 more comment
  • msksmack Sep 07, 2009
    DISREGARD!! WRONG AREA TO POST!!
  • msksmack Sep 08, 2009
    Thank you. I did try that before and I can't see anything related... any other thoughts?
  • Ken Derbyshire May 11, 2010
    Have you tried reviewing all of the programs in the "Add/Remove Programs" option under the control panel? See if one stands out ie, "AdAware v5.3" Just a thought
Tip
Block Ads
advertisements are annoying to all of us. They do create revenue for sites, but most of the time ,they are of little importance to the user and all they do is nibble away at your bandwidth. Sometimes, they can show inappropriate content as well. We are going to look at ways to disable or at least hide the ads off the screen with pretty much any of the most used browsers.Ad Blocking In Firefox
Ads come in all forms and pop ups are one of the most annoying ways of which ads make their way on to the screen. Firefox, like most other browsers today, stops pop ups from appearing on the screen.
For blocking of advertisements, there is an extremely useful and well known add-on called Adblock Plus. Get it fromhttp://adblockplus.org/en/. Click on the Installation link to go to that page to download the add-on. You have to click on the Allow button on the right top of the Firefox window to permit the add-on to be downloaded and installed. Restart Firefox.
Once Firefox starts, choose Tools > Add-ons. Click on Options for the Ad block Plus add-on. Click on Filter > Add filter subscription.Use the drop down for Subscription title and choose the lists you want to add and click OK. Follow the steps to add additional subscriptions.Once added, click on Filters > Update all subscriptions. Click OK.
Ads should now be blocked by Firefox, and even if you do find some adsthat do make their way through the filters, right click on the image ofthe ad and click Adblock image…
Flash elements can also be disabled by using the Flashblock add-on forFirefox. This can be downloaded and installed from http://flashblock.mozdev.org. Flash elements will only work when you click on them.
Ad Blocking In Opera
Opera has a built in popup blocker and an ad blocking feature as well.Using the ad blocker is as simple as downloading a text file andputting in the right folder. Opera’s ad blocking works by referring toa file called urlfilter.ini. There are many users who keep regularlymaintained lists of ad hosts and domains.
One of the most famous one and most used ones is Fanboy’s Adblock List(www.fanboy.co.nz/adblock/) Click on the Install now link or visithttp://fanboy.co.nz/adblock/opera/urlfilter.ini. Save the file as it isto a folder and then move it to C:Documents andSettingsYour_User_IDApplication DataOpera_folderprofile. Linuxusers must copy to the .opera folder. When done, restart the browserand ad blocking will be enabled. Visit the site from time to time toupdate your ad block list.
Ad Blocking In Internet Explorer
Internet Explorer has been heavily criticized for letting popups andads run loose but it too has a 3rd party add-on that users candownload. It is called IE7Pro and can be downloaded fromwww.ie7pro.com. Click on the Download Free, download the installer andrun it. In the last few steps of the installation you will be askedwhether you want to enable spellchecking and if you want to setEasyHome as your homepage. Uncheck the boxes if you don’t. Click Nextand finish the installation.
Restart Internet Explorer and you will find an IE7Pro icon in thestatus bar below or a button for IE7Pro Preferences in the toolbarabove. Click it and then on AD Blocker. Enable Flash blocker to blockflash items from web pages. You can also add your own filters in the MyFilters tab. IE7Pro brings many more features than just ad blocking toInternet Explorer. Prefetching and mouse gestures are just some ofthese few features.
Universal Ad Blocking Across Windows
Ads can also be blocked across all browsers and applications running inWindows. This is done through a file called HOSTS that is located inC:WINDOWSsystem32driversetc. Like the urlfilter.ini list that wasused for Opera, similar lists are available for Windows. The listredirects domains to other domains or IPs. This way, none of the adscan be downloaded to your browser. Manual entries can be made byopening the file in a text editor. If you download a HOSTS file, copyit to the path mentioned above.
It is also a good idea to also have a spyware removal utilityinstalled—they not only block ads, but malware and trojans as well.Spybot (www.safer-networking.org) for example is one of such software.Keep it updated and run it from time to time and keep safe distancefrom possibly dodgy links and your PC should be just fine!
on Jan 14, 2010 | Computers & Internet
Why can't I open my email without an ad wanting me to log into them.
Install an ad blocker like: Adblock, Adblock Plus, uBlock, uBlock Origins are the most popular ones.
AdBlock
Adblock Plus
uBlock
uBlock Origin
Depending on how much RAM you have depends on which version to install. Four gigs or less only install uBlock, or uBlock Origins as they are smaller and won't slow down your system. AdBlock is the smaller version of AdBlock Plus so not as small as uBlock or uBlock Origins. AdBlock Plus not only handles ads, it handles some malware and pop-ups as well. Requires a device with more than 4 Gb of Ram.
Nov 05, 2015 | Google Gmail
How do I get rid of ads? I am a member.
ads are a way sites use to keep running so use ad blockers with caution.
i use adblock plus which is a plugin on chrome and firefox
when you have adware do a routine clean with a app like ccleaner
Nov 28, 2014 | Computers & Internet
Turn on pop up blocker
My best advice would be to install a plugin/extension like Adblock. This not only blocks pop ups but removes ads from webpages. This can also be beneficial since certain websites may have not safe for work images in the ad photos.
May 24, 2014 | Compaq Computers & Internet
Google
Hello, install Adblocker, it blocks pop-ups, comercials, side ads, etc.
link: AdBlock
Dec 11, 2013 | Google Chrome
I do not want Match.com ads They pop up on my email page
The answer is to install a ad blocker on your broswer, i reccomend adblock plus, here are the links:
for firefox - https://addons.mozilla.org/en-us/firefox/addon/adblock-plus/
for chrome - https://chrome.google.com/webstore/detail/gighmmpiobklfepjocnamgkkbiglidom
Jun 07, 2011 | Yahoo Mail
Download Ccleaner software from Ccleaner.com and after installation remove all un wanted broken links, softwares and it have many more options.
Sep 07, 2009 | Google Chrome
Nokia N73 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
