Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
There was a power outage and when the power came back on, my t.v. no longer worked. When I try to turn it on, the red timer/pic off light is flashing intermittently. It is a 32" Bravia.
    Scholar:
  • 64 Answers
I bet you $120.00 you did not have a 1000VA UPS on it. If I was right, you can pay me now, and I can send you one.
You need a new TV.....or it will cost you $150.00 to fix.
The thinner they are the faster they blow...by the way they have a computer in there.
www.storminprotection.com
Posted on Sep 11, 2009
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Green light flashing won't turn on
Likely has bad 1000UF capacitors on DM module. this will prevent rebooting.
Apr 08, 2014 | Mitsubishi WS-65611 65" Rear Projection...
I returned from vacation last night and noticed all four of my coach lights were off. I thought...the timer needs to be reprogrammed due to a power outage while I was away. The red indicator light was...
1) You performed correct troubleshoot steps down the line.
Last thing would be to install defect timer on another light circuit in house, and see if problem is the timer or wire going to coach lights.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
2) EJ351C has 1 year limited warranty.
Buy new EJ351c and install single pole light switch until timer replacement is available.
Timer has easy 2-wire installation. Turn off power. Connect new timer just like old one was connected. Either timer black wire connects to either wire in switch box.
http://www.smarthome.com/25077/Intermatic-EJ351C-24-Hour-Mechanical-In-Wall-Timer/p.aspx
http://www.amazon.com/Intermatic-EJ351C-Programmable-Mechanical-Security/dp/B000Q9YUGU
Aug 08, 2011 | Intermatic Hardware & Accessories
I have a intermac ML200Rt and after a power outage the clock motor does not turn anymore. It can be manualy turned to black and red trippers to turn lights on and off. The manual overide switch works also....
If clock motor stopped working, then there are no replacement clock motors/modules for power packs.
Buy cheap plug-in timer, set power pack to override, plug power pack into cheap timer.
If you have sales receipt, Intermatic/Malibu ML series power packs have 5 year limited warranty.
Open following links for troubleshoot steps, warranty links, trippers, and tips for getting next power pack to last longer.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 28, 2011 | Malibu ML200RT - Low Voltage Power Pack...
My Sony Bravia KDL-40V3000 tv is broken, when I turn on the power it shows up the movie normally as it would but then 1-3mins later the TV turns off and the green power light goes off and the pic off/timer...
i dont know if the first post worked, but if your television is beyond repair and are interested in selling the base to it please please contact me at jav_54@yahoo.com thank you.
Mar 20, 2011 | Televison & Video
4 year old Mitsubishi wd 52528 has had flashing timer light then turns itself off since power outage. After turns itself off, can't get it back on, even with reset.
Need to unplug for computer to power down then plug back in, light will blink for a few then go out and you should be able to power on!
Feb 12, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
Aug 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
After a momentary power outage Panasonic LCD TV has a flashing red light and will not turn on.
Try using a different outlet, the outlet or the tv may have been damaged in the surge. In the case of the tv contact the manufacturer and see if it's still under warranty. There may also be a way to 'reset' the tv by holding the power button down, try looking in the manual or calling customer support. In the future use a surge protector, many of today's electronics are still sensitive to power surges, older tv's were more resilliant than today's in this regard.
May 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Red light flashes,10 sec after turning on. after power outage
Hi, thank you for visit fixya.
Do you need replace both stk 392-110, and check any resistor (2.2 ohms) for blown or open. You can replace this IC's for stk 392-150d9f769b.jpg
May 12, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Sony KV-27S42
If the screen won't come on then the diagnostic will never show. The 4 blinks is an error code. If the set is older than 12 years then it doesn't owe you anything, you got your money's worth out of it. Average life of any tv from that genre is 8-12 years. It's time for a new set, or take it in for an expensive repair ( pending parts availability).
C-Dog
Feb 10, 2008 | Sony KV-27S42 27" TV
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
181 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
