Question about Pantech Matrix Cell Phone
Phone rings, but can't answer it.
My phone will ring. I can't answer it and talk on it. However I can talk when it is on speaker. What is wrong?
    Problem Solver:
  • 12 Answers
Any phone that only allows you to talk only on speaker, is deffective. you should contact your service provider.
Posted on Sep 08, 2009
Hooking up fax to KX TG7871 Panasonic Phone
There is excellent support here on basic fax setups. You have what is known as "Distinctive Ringing Service". There are pros and cons to the various setups. I assume you recognize the rings and answer only when the ring for the landline talk comes on. The fax will pick up the faxes, and the answering machine will pick up the voice.
Need model number of your fax - google that!
Service manual for your phone.
http://service.us.panasonic.com/OPERMANPDF/KXTG7841-MUL.PDF
This link shows various configurations of setting up your phone/fax/answering machine or using an answering service.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00059780#Dist_ring
Distinctive Ringing Service setup While it is not available everywhere, a distinctive ringing service can be purchased from most telephone companies. With this service, more than one phone number is assigned to the same phone line. Each phone number will ring differently. The main number will ring with a normal single ring and the additional number will ring with a distinctive ring pattern assigned by the phone company.
When a distinctive ringing service is used, set the Rings to Answer to 2 and then follow the steps below to set the distinctive ringing pattern:
  1. Press Setup , press 4 , and then press 1 to enter the Answer Ring Pattern setup of the Advanced Fax settings.
  2. Use the Right Arrow to scroll through the available settings. When the ring pattern assigned by the phone company displays (double or triple rings), press OK .
Mar 06, 2014 | Lands Phones
Cannot hear phone ringing or people talking or hear phone dailing out tone.
Sounds like your speaker or earpiece could be bad on your phone. Return to your carrier or call customer service from a different phone.
Mar 07, 2013 | Sony Ericsson T630
Panasonic KX-T7731 Programming Manual
We have two phones KX-T7731 (Main phone) + KX-T7020 in another office. We talking on phone and another call comes in it use to ring on the spare phone. Now it does not ring until 4th ring and goes right into answering machine. It use to ring on second ring. Is there a way to program phone to ring on second phone after second ring?
May 03, 2012 | Panasonic KX-T7731 Corded Phone
In settings what is auto answer and anykey
Auto answer means that your phone will answer itself after so many rings. Ultimately it goes to speaker phone and you can just start talking.
Jan 31, 2011 | Cell Phones
I want the fax to work with an identa ring. How do I program this? As it is now I have to turn on the fax to receive. Does this HP work with identa ring?
The following set up assumes you have one conventional phone line, but two different phone numbers. One being your regular phone number and the other a distinctive ring for your fax machine
If that is what you have then this is how you set up the phone. Its important to know what type of distinctive ring your phone company will send to your phone. If it doesn't work you can talk to them about getting a different one than their default distinctive ring.
2 Set the HP all-in-one to answer incoming calls automatically.
Press the Auto Answer button until the light is on.
3 Change the Answer Ring Pattern setting to the pattern that has been assigned to your fax number by the telephone company, for example, double rings or triple rings.
For information on changing this setting, see Change the answer ring pattern
(distinctive ringing).
Note Your HP all-in-one is factory-set to answer all ring patterns. If you do not set the correct ring pattern assigned to your fax number by the telephone company, your HP all-in-one might answer both voice calls and fax calls or it might not answer at all.
4 (Optional) Change the Rings to Answer setting to one ring or two rings.
For information on changing this setting, see Set the number of rings before answering.
5 Run a fax test. For information, see Test your fax setup.
Your HP all-in-one will automatically answer incoming calls that have the ring pattern you selected (Answer Ring Pattern setting) after the number of rings you selected (Rings to Answer setting). Then it will begin emitting fax reception tones to the sending
fax machine and receive the fax.
If it is easier or you want to know other options which may be more applicable to your phone setup. You can find that information here.
http://h10032.www1.hp.com/ctg/Manual/c00235090.pdf
Jul 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Fax machine will not reset to be able to answer the phone
When you set your fax machine to answer on a certain number of rings it will answer it on that number of rings expecting it to be another fax machine. If you do not answer it before the aloted number of rings you will not be able to talk since the fax machine will be trying to talk in computer speak. To help you may want to set it to answer after more rings.
Jan 15, 2009 | Office Equipment & Supplies
Fix phone line
It sounds to me like the phone line coming into your home has a short on it so when someone calls your phone it asts as you have answered it. Report the line trouble to your local phone provider as "RNA" (ring no answer) normal phone trouble ticket terms.
Nov 21, 2008 | Lands Phones
Phone wont talk--it has talkingidfeatures
The ringer has to be on first. Usually the unit announces the caller’s name after the 2nd ring. If you turn on the answering system and set the ring count to “2” the unit does not announce the caller’s name. Set it for more than 2 rings for name announcement.
Jul 16, 2008 | Panasonic KX-TG5632 Phone
Changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
Feb 14, 2008 | Uniden Cordless Phone
Phone rings but when answered the caller can not be heard.
Your ear speaker is bad. You may need to replace it.. This one made by HTC. You can check on Ebay for replacement part. Other issue could be is the hardware part of the ear speaker may be broken or defected will cause loosing contact with the main circuit or you can say it is short. Only solution is open the phone and check for that area to see for any defective.
Apr 21, 2007 | O2 Xda IIs Pocket PC
Pantech Matrix  Cell Phone Logo
101 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
