Question about BYTECC 3.5in SATA + USB 2.0 External Hard Drive Enclosure for SATA Hard Drives (USBHD380SAUS2) Drive Case
Bytecc 2.0 to IDE/sata adaptor kit, the 3.5 IDE port has no power connection. The sata port does. Were do i plug the power in for the Hard drive?
  • 3,153 Answers
How can i to connect a hard drive sata with sata to ide adapter on biostar u8668d motherboard?
you will need to purchase a serial ata adaptor card for pci slot with support for sata 1/2/3 I believe. Try ebuyer.com
Mar 31, 2015 | Seagate Barracuda 7200.10 (ST3750640AS)...
How do I read a barracuda 7200.12 1 TB drive? I need to get data off of it, not boot on it
Hi
The easiest way that I have found is to get a kit that allows you to power the drive from a separate wall socket and connect a data cable from the drive to a USB socket on the computer. Such a kit usually consists of four components:
A mains lead - wall socket to black box transformer
The black box transformer - has outlet 4 pin molar for IDE drives
A USB cable ending in unit for connecting to an IDE drive or SATA cable
A SATA cable for connecting to the SATA drive (your Barracuda 1Tb in this case)
The components can be seen on this Ebay site:-
USB 2 0 TO SATA IDE Cable for HDD with Power Converter Adapter UK
The one thing missing from this set up is a power conversion cable converting the molar 4 pin power connector to a SATA power connector. These can be a molar plug to go into the lead from the black box and either a single SATA power plug, or a double SATA power connector as shown here :
Molex to 2x SATA Power Dual Power Adaptor Splitter Cable Lead Hdd Cd DVD...
This option is inexpensive and offers great flexibility in the type of drives that can be connected to a USB port, 2.5 or 3.5 inch, SATA or IDE.
In your particular case you may be able to get a dock that connects to a power supply and a USB port, with an opening in the top to take a SATA drive. These tend to be more expensive and only suitable for SATA drives not IDE.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 29, 2014 | Seagate Barracuda 7200.12 1 TB 7200rpm...
Turn into usb drive
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable http://www.youtube.com/watch?v=iE8t5IGr0e4
http://www.ebay.com.au/itm/USB-2-0-to-SATA-IDE-2-5-3-5-Hard-Drive-HDD-Adapter-/330612048804?pt=AU_Laptop_Accessories&hash=item4cfa0383a4
USB 2.0 to SATA IDE 2.5 3.5 Hard Drive HDD Adapter Kit
AU $8.09 free postage worldwide
You would have to remove the hard drive and use a usb sata ide kit
you will then have to connect it to your computer using a usb port
Aug 13, 2013 | Western Digital Caviar SE16 WD5000AAKB -...
Wd50000aakb make into a external usb
AU $8.10 free postage worldwide
How do i put my hard drive inside? me
Open the external case, by removing some screws, and sliding the cover away from the insides.
Connect your disk-drive to the "power" and "data" connections, and secure the disk-drive with the mounting screws. Close the case.
Jul 25, 2011 | BYTECC ME-350V4-ISA SATA or IDE to USB 2.0...
I have a Dell Dimension E520 running Windows XP. I have a Seagate Barracuda 7200.7 100 gb Ultra ATA hard drive (model number ST3100011A) with IDE connections (taken from an old Emachines). The plan was...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 22, 2011 | Computers & Internet
Connecting new hard drive
If the old one is still conected you can connect it the same way if not here is how to::
Well firstly they are 2 types IDE (large connector) and SATA (small connector)
IDE
of an ide cable has 3 jacks 1 for the main board and 2 for IDE drives
2 drive must be set to master and the other to slave
Set the drives by using the jumper on the back the instructions are written on the drives
Connect the Ide Cable and then the power and turn you system on
IF ITS SATA
connect the sata cable to both hard drive and main board
connect the power cable and your done!!
NB:: sata ports are labeled SATA 1 SATA 2 etc
IDE are LABELED IDE 1 IDE 2
Ide is a large grey cable black connector SATA is usually orange or red and small
Oct 26, 2008 | Gateway (M520HD80G) Hard Drive
I have 3in1 USB 2.0 to IDE & SATA Cable but nothing to show me how to use this kit
SATA 3.5" 2.5" IDE 3 IN 1 TO USB 2.0 CABLE ADAPTOR KIT
1 external connection kit
1 internal connection kit
The internal connect kit consists of 1 red USB connector cable
and 1 internal white male molex connector to SATA female power connector
( 1 yellow wire , 2 black wires , 1 red wire )
the external connect kit
consists of a 3 pin power adaptor (with a tiny plug to save space) feeding a power supply which powers either IDE thru a Molex connector or SATA through a supplied adaptor. Supplied also are data connectors to link the IDE or SATA hard drive with a USB port. Use this adaptor set to retrieve data from a hard drive when it is not mounted in a computer.
Selah :-)
Sep 14, 2008 | Computers & Internet
Connecting an IDE HDD to a SATA port using an IDE to SATA converter
Not complete product...need to buy additional adapter for IDE to SATA power source.
IDE drive will have to have the power source hooked up as well as the adaptor hooked up.
Installing the adaptor only will not work. Your computer should have the 4 pin plug for the power to the IDE drive, other wise you will have to buy another adaptor.
Mar 23, 2008 | Intel Motherboard
Computers & Internet Logo
398 people viewed this question
Top BYTECC Computers & Internet Experts
Stan Skaggs
Stan Skaggs
richie46
Martin Clarke
Martin Clarke
Are you a BYTECC Computer and Internet Expert? Answer questions, earn points and help others
