Question about Maytag MSD2454G Side by Side Refrigerator
Ice maker is inop. There is water to the door dispenser but not to the ice maker.
  • Maytag Master
  • 4,655 Answers
It’s more likely that your 61005626 Dual Outlet water control valve has become defective on the side that turns the water on for the ice maker. Sometimes the ice maker is the reason for this problem. The ice maker has a temperature thermostat that sometimes goes bad and will not tell the water control valve to come on after dumping the ice and the end of its cycle. The part number for the temperature thermostat is 627985 you can test the ice maker to see if the thermostat is bad by filling it with tap water and allowing the water to freeze. If after freezing the ice maker cycles and dumps the ice but does not refill with water then the water control valve needs to be replaced. Try that test and let me know what you find, Thanks, Sea Breeze
Posted on Sep 07, 2009
Ice maker inop
Water valve for ice maker may be bad. there are two valves with one supply line, one valve controls the water dispenser and one for the ice maker. you can ohm out the solenoids, it'll ohm if its good and won't if its bad
Dec 11, 2013 | Maytag Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
We have an Electrolux S/S side by side w/Ice&water though the freezer door. The water flow through the door has been inoperative for several months but the ice maker continued to work fine. Water...
check and see if there is a built in filter pack inside the back of the fridge or it could possibly be that one of the lines has froze internally and or the open close valve at the water inlet inside has worn out
Jan 18, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
I am getting ice but no water
Well you are getting water as the ice maker has to fill up each time that it cycles. What I suspect is that your water line, which passes down in the back of the crisper in the refrigerator side to cool the water has become frozen, perhaps. It also could be the valve that dispenses the water at the door has become broken/inoperative. Try using a hair blower on the valve ay the door to see if it has a frozen water slug.
Jan 10, 2011 | LG 26.5 Cu. Ft. Side-by-Side Refrigerator...
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
May 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Dispenser in door inop
i would look to the wire harness under hinge(its hidden in a plastic webbing), 7 or 8 wires running through hinge creating a pinch point and shearing wire(s), only solution offered by kit aid is door replacement (harness not available, molded into door) but at close to $700 for a new door, some well placed solder mends to the connections will work quite well( wire nuts to big)
Mar 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid KSCS25 Refrigerator Ice Maker Inop
you should not be able to push the stripper at all so that tells me that the gear on the icemaker module is bad. get part number 8201515 and you should be fixed up.
Jan 06, 2008 | Refrigerators
Door front water and ice inop
the bord is usually where the switch's are in front. There behind the push buttons. I would make sure your getting power to the bord and go from there. If you do have power there replace the bord. If not you will need to locate the tech sheet for the wireing diagram and trace the circut for the dispensor. Good luck
Jul 18, 2007 | KitchenAid Superba Architect KSCS25INSS...
Maytag MSD2454G Side by Side Refrigerator Logo
202 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
