Question about LG Prada KE850 Cellular Phone
2 days ago i dropped my LG Ke850 Prada phone on the ground. At first everything seemed to work fine, but after i found out that i cannot send/receive calls or msgs. and now on the screen it always says "No Network" even when the sim card is in. I tested the sim card with 2 different phones and it works fine. What can be the problem??? HELP!!!
No MMs settings
go to your networks website and you will be able to send yourself the settings
Apr 15, 2010 | LG Prada KE850 Cellular Phone
Tip
LG KE850 Prada Unlock Code
Does your LG KE850 Prada work only with your current service provider or, when you insert a SIM card from another network, do you see any of the following messages?
  • Enter Subsidy Code
  • Enter Subsidy Password
  • Enter SIM Unlock Code (Simlock)
  • Contact Service Provider
  • Insert Correct SIM Card
  • Wrong SIM Card
  • Incorrect SIM Card
  • Phone Restricted
  • Can't Undo Restriction
  • Locked Return For Service
  • Enter Unlock Code
  • Enter Special Code
If so, your LG KE850 Prada is LOCKED and we can help you remove this lock on your LG KE850 Prada in a few simple steps, allowing you to use your phone on any GSM wireless network anywhere in the world.
You will not have to mail in your LG KE850 Prada. No Hardware or Software required. No technical knowledge required at all. Simply provide us your LG KE850 Prada’s IMEI number and we do all the rest.
Three Simple Steps
  1. Simply provide us your LG KE850 Prada’s IMEI (which can be found by typing *#06# into your phone), during check out.
  2. After order placement, the Unlock CODES together with easy to follow instructions guides will be sent to your email address within the time frame given.
  3. Follow the unlocking instructions provided by
    Reasons to remote unlock your cell phone
    • Save a fortune abroad, by using cheap local SIM Cards rather than expensive roaming tariffs.
    • As usually subsidize the cost of the phone, by unlocking it you are increasing the resale value of your LG KE850 Prada by up to 300%.
    • Use your work and personal SIM Card in your unlocked LG KE850 Prada - no need to carry two phones again.
    • Get the best value tariffs by swapping SIM Cards to take advantage of the latest offers.
    • You never send your phone to anybody.
    • Fast and easy. You receive the instructions within hours; unlocking itself takes 1-3 minutes.
    • No opening your LG KE850 Prada and risk of damage to your device.
    • Very easy, no technical experience necessary.
    • No complicated software or hardware just enters Unlock CODE, and your LG KE850 Prada is PERMANENTLY unlocked.
    • Is safe and does not void cell phone's warranty.
    • Unlocking is a one-time event. It works for the life of your LG KE850 Prada.
    Warranty
    All our Unlock CODES are 100% genuine and guaranteed, if for any reason your unlock codes are not found in our database then we will issue a full refund.
Instructions Unlocking Instructions for LG KE850 Prada
How to insert the Unlock CODE into your LG KE850 Prada
  1. Insert a not accepted SIM Card and turn ON your LG KE850 Prada.
  2. Your LG KE850 Prada will display "phone restricted".
  3. Select Cancel
  4. Your LG KE850 Prada will display "phone restriction code".
  5. Enter the Unlock CODE you received from UnlockallCellular.com
  6. Select OK
  7. Your LG KE850 Prada is now unlocked!
on Apr 07, 2010 | Cell Phones
My LG Prada KE850 seems to be frozen, will not go to main screen!
Dec 15, 2009 | LG Prada KE850 Cellular Phone
Same thing
Unfortunately, it sounds as if the phone is damaged due to the heat. If you have a warranty call your phone carrier report it lost and send for a replacement.
Sep 01, 2009 | LG Prada KE850 Cellular Phone
Lg prada ke850 black screen
My Phone has done that a couple of times before. It would slowly start turning off more & more often then it wouldn't turn on with the same problem as you.
Turns out it was the battery as it was a couple of Months old & was out of warranty.
Aug 15, 2009 | LG Prada KE850 Cellular Phone
It wont turn on
hello,
i have the same intermittent problem, take the battery out and put it back in. shouldnt have to but it works
Cheers
May 17, 2009 | LG Prada KE850 Cellular Phone
My phone lg prada sb310 not detect network
Check LG site for directions how to factory reset it. Usually it is a combination of power and/or Vol+/-
Aug 29, 2017 | LG Prada KE850 Cellular Phone
Unlock prada phone
i have lg prada ke850. 'unlocked' cell phone, and just received in mail and activated. as soon as i turn it on, it shows 'locked'. i hit the unlock side key but nothing changes. pls send me a solution. lg manual is here but so poorly written i cant understand. even it does not show cervice center in usa nor it has index page in the back. worst manual i ever seen.
Oct 02, 2008 | LG Prada KE850 Cellular Phone
Prada ke850
if you have the prada KE850, not the later prada II, you cannot make or receive video calls, as it is not a 3G phone.
Sep 30, 2008 | LG Prada KE850 Cellular Phone
LG Prada KE 850: Screen Cracked
There are tons of places in Asia. Just check around the major city cell phone retailers. Becareful though, there are lot of scams too. Goodluck.
Feb 25, 2008 | LG Prada KE850 Cellular Phone
LG Prada KE850 Cellular Phone Logo
78 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
