Question about Ford Garden
My 9N Ford Tractor won't start with a new 6volt battery.
The battery on my Ford 9N tractor went dead. I left the tractor out overnight and it rained heavy. I have changed the battery and now it tries to turn over but will not fire. I can't figure out what to do.
  • Ford Master
  • 8,404 Answers
No water in the distributor or wires ... right? Spray with a popular water inhibitor and/or dry with a rag and or air pressure.
Posted on Sep 07, 2009
Don't know how to read the hydraulic dipstick for a 1944 ford 2n tractor
Ford Tractor Hydraulic System - My Ford Tractors
www.myfordtractors.com/hydraulics.shtml
All N-Series Tractors - Ford-Ferguson 9N, 2N, and Ford 8N ... 6 - How long has it been since you changed the hydraulic fluid? ... If that didn't do it, read on. ... then remove the bottom bolt from the inspection plate that has the hydraulic dip-stick.
Yesterday's Tractors - Fifty Tips for Ford 9N, 2N and 8N ...
www.yesterdaystractors.com/articles/artint268.htm
I'd like to say that the reason I have an 8N Ford tractor is because that's the tractor ... The N tractors have a common sump for the rear end, hydraulic pump andtransmission. ... (Read the label.) .... Take the inspection plate with the dipstick off.
Ford 8N, 9N, 2N, NAA Tractors Information - SSB Tractor ...
www.ssbtractor.com/wwwboard/messages15/
Helpful information and resources on Ford 8N, 9N, 2N, NAA tractors from SSB Tractor, a leading provider of tractor parts, manuals, implements ... 1944 ford 2n: What type of oil to use? and whats the oil pressure should be? ...... N Series Trans/Hydro Fluid - Interesting To Read ... Ford NAA/Jubilee Hydraulic dipstick location?
Jan 01, 2016 | Ford Cars & Trucks
Ford 9n converted to 12 volt alt still 6 volts at dis. runs rough till i jump 12 volts to coil and then it runs good. Will this damage coil and points?
If you are doing 6 Volts at the distributor you must either have Resistor wiring or a separate resistor in the system. They make both 6Volt and identical 12Volt coils for your unit.
You will eventually burn up a 6Volt coil if you use 12Volts on it. There is an aftermarket company which has Antique supplies. Carpenter(Maybe John) has supplies for Tractors, cars and trucks that are earlier models.
Do a Web search using his name and marry it to Tractor parts, etc.
Sep 09, 2011 | Ford 8n,9n,2n, Tractor Starter With Drive
My 2n tractor only puts out 3-4 charging. The
The 12 v conversion is the way to go. 6 v is a pain. It's getting harder and harder to get parts, and running off of battery power leaves a lot to be desired, especially if you've ever had to haul a dead battery back to the barn. I had a Farmall model "B", 1947, 6 volts. 12 volts was like a whole different tractor. Just my humble opinion!
Best regards, --W/D--
Aug 18, 2009 | Ford 2n, 9n, 8n Tractor Left Taillight...
Having trouble with 1942 Ford 9N tractor.
You have a ground not grounding could be the switch itself and it may be the voltage reducer to the coil.
Aug 17, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
No spark to my ford 9n tractor
you are in the wrong place that is the battery regulator. go to the distributor and pull the cap where you see the four spark plug wires. Inside you will see a set of points and a condenser. there you should have 12 volts. Get back to me after that. donnyb60
Mar 22, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Garden Logo
421 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
fordexpert
donald boissonneault
Are you a Ford Garden Expert? Answer questions, earn points and help others
