Question about Moen Posi-Temp Single HandleTub And Shower Faucet
My replacement Danco 88675 posi-temp cartridge still leaks (steady stream). I originally had a Moen 96909 cartridge and can't seem to find one anywhere. What to do?
  • Anonymous Mar 18, 2014
    Trying to find where small spring goes..inside cartridge or outside
  • 129 Answers
Call a plumbing supply house in your area, they will be able to help you.
Posted on Sep 27, 2009
What will replace a Dance 88005 cartridge?
You probably have a Danco cartridge. Danco parts are available from some "Big Box" home improvement stores.
Jun 10, 2014 | Moen Posi-Temp Single HandleTub And Shower...
My single moen posi temp shower knob wil not completely turn off my water. In the closed position it still runs a slow stream of water.
Remove the handle and see if it will turn off without the handle and if it will reposition the handle alignment and your good to go. If no the cartridge will need to be replaced.
Feb 12, 2011 | Moen & Posi-Temp Single Handle Shower Or...
When i turn it on it is only warm at best. when i turn it all the way hot the water comes out in a trickle. all our other showers and sinks get hot water just fine. this is a single handle shower and does...
You will need to remove the old cartridge from inside the shower valve body and either refurbish it with new rubber seals and O rings or replace the cartridge altogether (preferable). It's not a complicated fix but the Posi Temp cartridge can be a bear to remove. Moen and Danco make special 'pullers' to make the cartridge removal go a little easier (sold at Lowes/HD and plumbing supply for anywhere between $15 and $35 but well worth it, IMO).
Oct 27, 2010 | Moen & Posi-Temp Single Handle Shower Or...
We replaced the cartridge of our one handle shower faucet and now the spigot leaks a steady stream of water
wrong stem.. the body of cartridge where the o ring seats into the body of the faucet needs to go all the way down.. try looking at new ong very carefully because they are almost identical except for this
Sep 02, 2010 | Danco Faucet Cartridge
I replaced a Moen shower cartridge with a Danco 88675 part. It stopped the leak, but ever since the repair I have water hammer in the pipes when I shut all the upstairs fixtures off. I have bled the...
The cartridge is the culprit. Replace it with an OEM Moen cartridge. What happens is that some replacement cartridges may not operate the same as the moen brand when they are in the closed position. This can sometimes result in the water hammer effect you are experiencing. Change the cartridge and it should alleviate the problem. If it doesn't work let me know and we will go at it from a different angle.
Aug 03, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Had a leaky Moen Posi-Temp shower faucet. Installed an Ace Hardware replacement cartridge. Fixed the leak, but now have a water hammer noise in the vicinity of the shower. Is this a common problem with...
I'm not aware of any problems with non moen replacement parts being the cause for a water hammer problem. Start with the simplest and cheapest correction which is using a moen replacement cartridge. If the water hammer persists then you may have to install a water hammer arrester in the plumbing system. This is basically a shock absorber in the plumbing system to stop the effect of water hammer. An arrester will cost you around $10 to $15 at your local plumbing supply shop. If you are not comfortable soldering copper then you will want to hire a licensed plumber to complete the work for you.
I had the same type of problem with an older toilet in my house. It developed a water hammer when it shut off after filling the tank. I replaced the fill valve with a generic universal replacement for about $10 and it stopped. Again sometimes the simplest fix will work. Let me know how it works out.
Jul 19, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Installed new Moen posi-temp cartridge. Hot & cold water is correct but water will not shut of*** the way.
I just had the same experience, except I used a non-Moen cartridge. (It was from Ace Hardware, and Ace told me that Danco was the manufacturer.) When I pulled the cartridge back out, one of the two hard plastic seals on the side of the cartridge had torn, presumably on the sharp metal opening on the water supply pipe. I'm guessing there's something wrong with one or both of the seals on your new cartridge.
Jul 13, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Replaced danco cartridge 88198 three times. only
Danco is an after market faucet parts company that recreates parts cheap for hardware supply chains and such. You would be ahead to try and find the brand of faucet you are trying to repair and get OEM parts. They will probably cost a little more, but will hold up a lot better. I hope this helps.
May 18, 2010 | Danco Faucet Cartridge
Does danco offer a replacement cartridge for american standard cartridge O28610-0070A
Danco is an aftermarket supplier of plumbing repair parts for almost all major brands. Look for a danco part that looks like the part you need then check the "compatible with" list on the package.
Apr 12, 2010 | Danco Faucet Cartridge
Replacing Moen Posi-Temp shower handle with a Danco and temp of water is now different - cold to left, hot to right and no flow when this knob is in center. Help?
Take the knob off and rotate 180 degrees and put back on. Just take the knob off, turn 180 and screw back on. New stems many times are in the half way position from the factory. You are not the first this has happened to. My answer assumes you just changed out the cartridge.
Please rate this response and Good Luck, Phil
Dec 27, 2008 | Home
Moen Posi-Temp Single HandleTub And Shower Faucet  Logo
2,894 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
