Question about Toymax Magnavox 47MF437B 47 in. LCD TV
Power Light 47MF437B LCD TV 12 months old has no power light does not come on tv will not turn on,
  • Toymax Master
  • 5,568 Answers
The most likely failure is the main power supply. You may be able to identify it with the following instructions:
Unplug your set overnight to allow potentially hazardous voltages to discharge, remove the back panel of the set so you can see the guts.
Look for a smaller board with larger parts on it; some cylindrical (capacitors), others block-like and relatively large (chokes and transformers).
You should also see a relationship between the board and the incoming AC.
Check the board for a label or if not present, a stamped-on number.
Call the manufacturer's service center with your TV model number and the number found on that board and inquire about repair/replacement costs; if both are offered, they won't be that much different.
If you must buy a new board, don't dispose of the failed one as there are smaller companies that can repair it for less than the mfr. and then keep it as a spare as this problem will likely arise again.
Unfortunately, the Magnavox name is owned by the Japanese Funai company which is known for poorly designed and not very reliable products.
Posted on Sep 07, 2009
The issue is the power supply, mine did the same thing. On the power supply board behind the back panel (the one the AC input goes to), look for electrolytic capacitors with puffed-out tops. Replace them. I had 4, one 1000 uF and 3 640uF, and the 640's were the hardest to find. Once all bad capacitors have been replaced, you should be back up and running again.
Posted on May 13, 2011
    Problem Solver:
  • 5 Answers
Did u fix ur tv? i sharred my screen on my tv?if u want to get rid of urs ill buy it for parts let me know (i need the screen)
noe28cervantes@yahoo.com 47mf437b/37 47inch magnavox
Posted on Feb 07, 2010
Why my almost 2 year old 20" lcd tv will not come on?
If the green light is on, power is getting to the TV but there may have been an internal power supply failure
Feb 10, 2013 | Sanyo DP26640 LCD TV
Magnavox 47MF437B/37 works fine until turned off. The red standby light comes on but the TV will not turn back on again. I have unpluggged the TV then plugged it back in again. Sometimes the the TV will...
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope it work with the solution
Jun 12, 2011 | Toymax Magnavox 47MF437B 47 in. LCD TV
Aquos model LC46D64U...approx 2 years old..Won't power up and get the power light flashing 3 times then the OPC light once..which is repeated...Any ideas...I believe this is quite common with Sharp TV's
I have a Sharp LCD 46 in.tv do this often.Yes,it is.This problems,the tv Tuner signal board have problem,but the tv is still useable.The POWER and OPC light indications flashes.Just push the power switch again,wait see tv turn,not POWER and OPC flashes again,push the power switch agian and wait.Have to do this like 3 or 4 times sometimes,than the tv backlight will come on,tv will work.Don't know but,if u require to pushing power button more 10 or 12 times,the tv Tuner signal board don't take an turn on the tv backlight get the tv to work.The Tuner signal board is dead,time to replaced the tv Tuner signal board.
Oct 18, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Powers on but no picture or sound
i need a screen off a 47inch magnavox if u coudent fix urs and ur interested in selling me ur screen let me know
(47mf437b/37) noe28cervantes@yahoo.com
Jan 04, 2010 | Toymax Magnavox 47MF437B 47 in. LCD TV
Proscan 19la25q 19in lcd
Is there a red L-E-D power light beneath the screen? that is the power off light(red). Watch closely to see if that red light momentarily turns green and then immediately red again when you are attempting to turn the tv on, that indicates a bad power supply. There are replacement power supplies on ebay. Be sure that the positive (+) is the center hole of the plug. Most likely all of them are. The output plug is 5.5mm x 2.5mm in size.
http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=12+volt+5+amp+power+supply&_sacat=See-All-Categories
Mar 08, 2009 | Proscan 19LA25Q 19 in. LCD Television
Toymax Magnavox 47MF437B 47 in. LCD TV Logo
776 people viewed this question
Top Toymax Televison & Video Experts
matt martin
matt martin
Paul
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
