Question about Maytag Neptune MDE5500AY Electric Dryer
How do I get the top off maytag dryer, to get inside of it...Model # 6200
  • 304 Answers
The complete Service manual is at the link below. The removal of the top is on page 5-2. Good Luck. Unplug unit before servicing.
MDE/MDG6200
Posted on Sep 07, 2009
How to remove top and front panel on Maytag Dryer model MDE9206AYW
To access these parts you first need to first lift the top up. This is done by pressing the clips inward. These are located on the left and right side in between the top and front on the dryer. When this is done the top will left up and backwards. Next, on the upper inside there are two screws, usually 5/16" bolts, that will need to removed to take the front off. Now you'll will access to the inside of the dryer. The belt will have to be removed to to take the drum out to test the rollers.
Jun 06, 2012 | Maytag Dryers
I have gas dryer, model SDG4606, and the light inside drum does not work. How do I replace it?
When you open the door on your dryer your light bulb is located at the top of the opening. There will be a clear plastic cover over it that is held in place by one screw. Remove the screw and allow the cover to hinge away from the opening. The bulb is Maytag part number 67001316.
Sep 17, 2010 | Maytag SDG4606A Gas Dryer
Model #MDE8057AYW I need to know how to get the lid off so I can see if I need a new belt
1.Unplug the electrical cord of the Maytag electric dryer from the electrical outlet.
2.Open the dryer door and locate the four screws on the inside,unfastening the screws with a screwdriver.
3.Pull on the corners of the top front panel,rolling the corners forward to release the clips.
4.Tip the front panel straight out and slide it up until the panel comes loose of the clips.
5.Set the front panel aside and slide the top of the dryer forward.
6.Lift the top of the Maytag electric dryer up,tilting it back and resting it against the wall.
Aug 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
One of the paddles inside the dryer has come loose, how can I fix this?
remove door screws and screws on opposite side. pull front forward and down. remove two brackets at top corners to raise top (unplug machine of course). screws are on outside of drum.
Jun 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Heating problem
Unplug the dryer.
Take a putty knife and insert it at the top of the front panel just below the lid and push the 2 clips in.They are about 2 inches in from the right and left sides.
Raise the top lid towards the rear of the machine.
Remove 2 screws on the inside top corners of the front panel. Remove the front panel.
Remove the belt. Remove the drum.
The heater will be on your bottom left.
Apr 12, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
How to remove lint tray receiver: maytag dryer model#pye2300ayw
Unplug first with a straight blade screwdriver, pry up on the top of the dryer where the front wall of the dryer and the top meet. there are 2 screws 1 on each side inside the dryer where the sides and front meet, remove them and unhook the wires from the door switch. the whole front will now pull out and up, now open the door remove the 2 screws at the bottom of the door opening and the whole lint tray will pull out. sounds like a lot but only takes about 5 minutes.
Nov 30, 2008 | Maytag PYE2300AY Electric Dryer
MDE 6200 AYW Maytag Atlantis broken baffle
To lift the top and access baffle screws, proceed as follows;
1. Remove door hinge screws from cabinet. Door can remain in place.
2. Remove screws and plastic retainers opposite door hinge
3. Grasp each side of the top front panel and pull forward. Lift to remove panel
4. Remove lid retainer clamps from each front top corner.
5. Lift top to access drum baffle screws.
If you need further assistance, let me know
Regards,
reg501
Jun 30, 2008 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
763 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
