Question about Tappan TGF363 Gas Kitchen Range
Oven not coming on
I have a tappan automatic pilotless ignition stove. My stove top comes on but my oven does not and i can't for the life of me figure out whats wrong
I have a tappan gas stove the top comes on but the oven wont come on.
Posted on Mar 18, 2010
HOW TO SOLVE TAPPAN OVEN MGF334BGWA FROM COMING ON AND GOING OFF RANDOMLY
Thank you for your post, friend!
I understand that your Tappan stove is coming on and off randomly. It sounds like a possible issue with the switches or control panel. I would recommend seeking assistance from a professional technician for proper diagnosis and repair. I hope this is helpful. -Matt
Oct 18, 2014 | Tappan Ovens
I have a Hot Point Gas Stove my burners all turn on but when I turn on oven nothing seems to happen
If you have a pilotless model it is very likely that your oven igniter is bad. This is fairly easy to replace. A contunuity check will show if the igniter is bad.
Nov 25, 2013 | Stoves Ovens
Gas Tappan oven will not power up after power outage
make this test and use the multimeter. God bless you
No power
Make sure there's power getting to your range, oven or cook top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
Nov 04, 2013 | Tappan Kitchen Ranges
I just cleaned my Tappan NF40700643 Automatic Pilotless Ignition gas oven and now the light bulb (bulb is good) the and oven does not get hot .... it does nothing. Help ... I have dinner ready to put in...
if not even the light bulb is working it sounds like the plug is out or the fuse blew,pull the stove out,plug in a hair dryer or something to see if there's any power at the outlet or just go check the fuse or breaker box
Aug 16, 2011 | Tappan TGF363 Gas Kitchen Range
Oven will not turn on
You need to replace the igniters for the top or the ignition filiment if it is the bottom.  You can get these at any appliance center.
Mar 12, 2009 | Ovens
Oven wont light
Mine did that and I found the ignitor for the oven was bad. It was the "glow" type for pilotless ignition and it was burned out. It is supposed to glow bright red and the gas comes on and the oven will light. It was easy to tell that it was bad. But to check it I swapped the broiler ignitor with the oven ignitor and the oven worked.
Dec 20, 2008 | GE JGBP33SEHSS Stainless Steel Gas Kitchen...
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
Older Tappan range oven not lighting.
There is no way to light the oven manually. The gas valve will not open until the oven ignitor draws enough current. But replacing the ignitor will fix ya up.
Nov 19, 2008 | Tappan TGF320 Gas Kitchen Range
Oven and stop top problems.
The problem may one of two things - defective safety valve or defective ignitor for the oven.
The burners need to be cleaned up (the orifice ports) for the oven top
Regards
Sep 20, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan TGF363 Gas Kitchen Range Logo
1,481 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
