Question about E-Machines eMachines Monitor E15T4
Emachine 15' lcd monitor
Can the monitor work with an older HP computer? A box comes up in the middle of the screen saying out of range can't close box mouse goes behind box.
  • schoon92 Aug 22, 2008
    same problem on start up out of range message comes up.
    Brigadier General:
  • 6,966 Answers
Your query - "can the monitor work with an older HP computer?"
Normally yes, assuming that there is no hardware fault. The message is an indicator that somehow the settings of the display of the old HP computer does not match that of the Emachine 15' LCD monitor.
Perhaps what you can do is to run the old HP PC in Safe Mode (press F8 before Windows starts), using the arrow keys, select top mode setting in the Menu which is Safe Node, hit enter. Windows should then start and normally should be viewable no matter what settings the monitor can handle. On Safe Mode Windows, right click on any clear area of the desktop, click on properties, Settings tab, move the Screen resolution to the left most position, set the color quality to the lowest possible choice. Click on Advanced button, click on Monitor tab, set Screen Refresh Rate to lowest possibler, OK, OK, reboot.
Hope that this be of some help/idea. Pls post back if things worked out or should you need additional information.
Good luck and kind regards
Posted on Dec 09, 2007
Screen says out of range
This can happen if the output from the computer has the resolution set higher than your monitor is capable of displaying, or the refresh rate is higher than the monitor can display. Set the refresh rate to 60Hz. Try connecting a friend's monitor temporarily.
Jun 29, 2012 | AOC A15X221 15 in. LCD Television
My benq fp547 says its out of range...the image still shows up but there is a bar in the middle of the screen that says out of range...any ideas?
In windows change your display refresh rate to 60Hz. If you cant get into windows, boot into safe mode by holding f8 after a computer restart and change the settings from there.
Sep 09, 2010 | BenQ FP547 15" LCD Monitor
Input signal out of range
Did you mean "out of range". Try reloading video drivers. If that doesn't work, perhaps screen cannot use that resolution.
Jun 28, 2009 | HP Pavilion F1523 15" LCD Monitor
Dialogue box in the middle of the screen
Out of range usually means that the computer is trying to use a resolution that is unsupported by the monitor. Try loading the PC in safe mode (for windows, press F8 before windows loads) and change the desktop resolution to 800x600, which is supported by pretty much any monitor. Restart the computer normally and you should get your video. Once inside windows you can experiment with different resolutions, and when it goes out of range, just wait 15 seconds for it to go back to 800x600.
May 15, 2009 | Microtek 710S 17" Flat Panel LCD Monitor
HP Monitor comes on with bright white screen since changing PC
Try using a different wall outlet to plug in your monitor. Believe it or not this actually may help.
What ever breakers you are talking about to get the monitor going doesn't really have anything to do with the drivers. Monitors are "plug and play" meaning the drivers are installed for you when you plug it in. It"s possible you don't have the connections on securely or maybe one of the pins are bent. Does it say "restore active desktop" anywhere on your screen?
Also possible the power supply isn't strong enough for your lcd.
Dec 10, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Hp pavilion f1503 momitor
Hold the MENU button for 10 seconds to lock or unlock the OSD
Aug 05, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Black screen
Hi
my problem was fixed by viziks from FixYa dated Sep 12
replaced 2 push pull transistors 2sc5707 in high voltage transformer circuit
Transformer used for backlight lamps
Both monitors now working THANKS VIZIKS
Feb 09, 2008 | HP vs15 15"LCD Flat Panel Monitor
INPUT SIGNAL OUT OF RANGE
some how your screen resolution has changed above or below what your monitor can display. you need to boot your computer using another monitor that can work with the resolution your computer has switched to(i used a spare crt monitor when it happened to me) change your resolution in display properties to a normal level like 1027x768, and while the computer is on swap the monitor cables to verify the lcd is working.
It is perfectly safe to unplug the video cable and plug it back in while the computer is turnned on.
Dec 26, 2007 | Relisys TL775 17" LCD Monitor
Benq monitor
Change your monitor frequency to 75hz on the screen refresh rate on monitor
Oct 25, 2006 | BenQ FP567s 15" LCD Monitor
Hp pavilion vf51
It is the inverter board that is causing the screen to be feint. But is was the video resoloution being set too high that made it give the "out of range" message.
It's not easy to get anywhere to repair LCD monitors, and the prices could be well out of scope to bother with the repair.
Having said that, you can now call a few TV repair centres close to you and ask for a quote based on repairing the inverter circuit.
Hope that helps =)
Aug 17, 2006 | HP Pavilion VF51 15 in. Flat Panel LCD...
E-Machines eMachines Monitor E15T4 Logo
161 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
