There is a left handed screw down at the bottom of the chuck. I believe it is a flathead screw. You need to make sure you are in the lowest gear and turn that screw clockwise. It seems odd, but turning to the right will loosen the chuck screw. Once the chuck screw is removed then you need to remove the chuck from the spindle. Remove the chuck like a regular screw. It has regular threads and should be removed by turning it counterclockwise. Good luck
Need to remove the chuck on my 3/8 milwaukee drill. I opened the chuck and removed the screw in the...
(More)
Need to remove the chuck on my 3/8 milwaukee drill. I opened the chuck and removed the screw in the bottom but can't get it off. does it pry off or unscrew? right or left hand screw???
I need to look at a manual for Makita HR2510 Rotory hammer I think I need to add oil but Im not sure...
(More)
I need to look at a manual for Makita HR2510 Rotory hammer I think I need to add oil but Im not sure where to put it. Theres a sign on it, a red circle with line through, telling me not put in top port which looks like the obvious place, hence sign.
The drill bit holder on my cordless drill is stuck. I blew canned air into it, then WD40, then hit...
(More)
The drill bit holder on my cordless drill is stuck. I blew canned air into it, then WD40, then hit it with a mallet. What else can I do?
