Question about Garden
Starts right up, but then engine dies before even have time to move lever from choke to run. Have cleaned air filter and carb, and replaced spark plug. Had been working great; this is first problem I've had with it.
  • bulldogchief
    bulldogchief May 11, 2010
    Need more info such as what make/model blower is it?
  • 124 Answers
This is as simple as it gets. If the carb has not
been rebuilt in the past 2 or 3 years it will need to be rebuilt or
replaced. The average life of the diaphragms is about 2 to 3 years,
If your carb has limiters which will only allow the adjustment
screws to turn about 1/2 turn, you will likely not get any relief from
adjusting the carb. You will have to take the unit to a local dealer
for help. Most likely you will need to replace or rebuild the carb.
If you can not find help in your area try Southern
Supply Co. Their number is 205-833-2525 and they have anything
you will need for Homelite products and they will ship anywhere.
Ask for Jason. I hope this helps.
Posted on Sep 14, 2009
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
I need to rev the throttle to prevent the engine from stalling.
Try checking these two things: idle adjustment (usually milled screw on the carburettor) or there could be a problem with the governor - this is usually a plate that is driven by the airflow from the cooling fan, check that this moves freely (usually a shaft from the cooling fan on to the carburettor butterfly valve), if this is not free, then the engine will only run on idle, will not reach running speed, garden debris can cause it to jam...
Nov 06, 2013 | Ardisam Earthquake Mini Cultivator 43cc...
My 1998 Suzuki gsx 600 only starts ion full choke and won't stay running off of choke unless I run it about 20 min. Even then it dies off of choke what could be the issue?
What you have here is a fuel to air ratio issue. You are getting to much air to the engine and that is causing it to die when the choke is off. There is a screw that you can adjust for the air mixture, and this may take a little time to correct as it is a trial and error thing. All bikes are going to be a little different, even if they are manufactured by the same company. I hope that this information was useful as that is my goal.
Jan 18, 2011 | Suzuki GSX 600 F (Katana Motorcycles
How to start a kawasaki th48 2 stroke engine
Typically:
1. Press primer button 6-7 times until you see fuel flowing
2. Engage the choke lever to full choke /--/ pull cord 3-5 times until engine begins to start
3. Move choke lever to 1/2 choke and pull cord 2-3 times until engine starts - - allow to warm up (about 30 seconds) and move choke lever to no choke / / /
4. If engine does not start, repeat 1-3
If engine does not start, repost with more detail. Thanks! :)
Sep 25, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
2002 Hyosung GV250 running problems
Time for carb cleaning , blow the jets with compressed air,check the float level.
Check the spark plug and replace if neccessary.
Check the air filter too, and if you don't have an 'inline' filter for your fuel line,install one.
Basically yr bike's engine needs a tune up...check the valve clearance too!
Hope this helps!
Oct 30, 2009 | 2002 Hyosung GV 250 Aquila
My weed eater blower starts and i can run the engine at full
See if there's a plastic adjustment/tiny little unit with standard slot,try half turn.
Jul 18, 2009 | Poulan Garden
Starts on choke but dies when moved off choke
If it will start on choke and die when choke is taken off...the carb needs to be taken off and cleaned. The main jet in the carb is probably clogged.
Apr 09, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Garden Logo
210 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
