Question about Stanley Bostitch N88rh Framing Nailer Driver Piston 158582
Bostich N88rh fires like a machine gun
As soon as air is hooked up. even without front safety pressed. I have oiled, tapped, thumped hooked and unhooked air numerous times...no change. Also air continues to leak through head when pressure is low. What can i check at the spring loaded out end?
  • jason king
    jason king May 11, 2010
    seal it blown, get a rebuilt kit
I Put a new trigger in and the safety on the head of the gun does not have to be pushed up in order to fire a nail in a board. I think when i pput it back together it was not done right. I do not have the instruction book.
Posted on Aug 04, 2010
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
You either have a piston stop bumper failure or some damaged orings. Look on the schematic and the piston stop bumper is number 11, part #107236. A lot of times the piston stop bumper will disintergrate due to becoming brittle from the compressed air and not having enough lubrication. Look for small plastic balls in the head under the valve. If you see little plastic pieces than that is what remains of the piston stop bumper. You will need to remove the valve from the head cap in order to inspect the bumper. Also inspect all orings. The slightest damage can have big effects. One other thing to look for is damage to the plastic valve that rides on 3 orings. (2 out and 1 in) I don't believe you have valve damage because you say it is firing like a machine gun. This is almost always the piston stop bumper.
Posted on Sep 09, 2009
On the trigger of my Bostich Spiral load nail gun AND my Bostick trim nail gun air is leaking profusely from the trigger. Nail guns were not in use for about a year. When I first used them this weekend,...
A nail gun works on compressed air.
When you hook the air hose to the gun it fills a cylinder with air pressure.
When you pull the trigger. the cylinder pressure is released onto a firing pin that shoots the nail.
The air pressure line is also connected to the trigger and therefore the trigger has to be sealed.
When ever using a nail gun, you add a bit of gun oil in the back of the gun (not 3-in-1motor oil, it has to be non-detergent gun oil)
If you haven't used the gun in a while, it is best to oil up the gun and let the oil run down into the gun.
If you use anything but gun oil, the seals will give out.
Your trigger seal has given out. It is probably an 'O' ring. You can access it by taking it apart. Look for the O ring.
Bostich makes re-build kits for the different guns that you can buy on-line.
Back when I was in construction, there were several nail gun shops that sold and serviced nail guns, and sold nails to the contractors. I don't know if that business model is still active or if you have to send the guns to Bostich service center.
Oct 18, 2010 | Garden
Fires like a machine gun without pulling triger. Close call
Bostitch N60FN finish nailer:
I replaced the o-rings and reassembled now when I put air to it the driver does not return and when I pull the trigger I get a "puff" sound.
Sep 07, 2009 | Stanley Bostitch N88rh Framing Nailer...
Bosticth framing nailer fires when hooked to air
seems like the piston is sticking. put 10 drops of oil in air inlet, and fire gun, try to work it loose.few drops of oil on head moving parts too will help.
Sep 05, 2009 | Stanley Bostitch N88rh Framing Nailer...
Nail is jammed ln a bostich n88rh how do you clear the barrel
I have solved my problem, I am going to dump this bostich even though it is a brand new product that has not been used in over a year, has only fired approxamately a dozen nails and go with another product that has an honest customer relation rep that does not charge you for information on their products.
I will also remember my experiance with this company and there products
Yours truly
Charles Marleau
Jul 09, 2009 | Stanley Bostitch N88rh Framing Nailer...
FIRES MULTIPLE NAILS WHEN AIR IS HOOKED UP.
Your trigger plunger is not seating to close off the air. Then your safety interlock is also not working properly. Needs a rebuild of all pertinant parts associated with the firing. There is a vlve in the the body that works in conjunction with the safety interlock and the trigger.
Jul 04, 2009 | Stanley Bostitch N88rh Framing Nailer...
Bostich Framing Nailer
Try getting a can of air gun lubricant from a good hardware or specialist store that sells nail guns. Often the feed mechanism just gets stuck and needs a bit of spray lube to get move again.
Jun 15, 2009 | Stanley Tools & Hardware - Others
I have a bostich framing nail gun and as soon as i hook my air hose up to it the air comes directly out through where the driver is, dont even have to pull trigger, can u help, need gun operating to make...
The o-rings need to be replaced and/or the trigger assembly is defective. Look around at local lumber yards for a "Bostich days" promotion. Often with the purchase of a box of nails, the Bostich rep will "service" up to 2 guns for free. If this is not an option for you because of time, you can purchase the o-ring kit and replace the rings yourself. This is not a difficult repair. Also, be sure to lubricate the guns with pneumatic oil frequently as this will keep the rings lubtricated and prevent them from drying out and leaking.
Hope this helps,
Dan
Nov 30, 2008 | Stanley Bostitch F21PL Nailer
Bostich nail gun plumger not retracting
spay with pb blaster while rapid firing gun into a piece of junk material , once free oil with a small amount of hold or sewing machine oil and then oil after each use
Nov 27, 2008 | Heavy Duty Stanley Bostich Heavy-duty...
Stanley Bostitch N88rh Framing Nailer Driver Piston 158582 Logo
220 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
River bottom
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
