Question about Char-Broil Grilling
Gas knob and valve has broken were will i get a new part?
  • gazzandkazz Sep 07, 2009
    i dont live in america i am from england
  • 388 Answers
Go to your local big box home improvement store (Home Depot, etc) and ask a salesperson in the grill area. If you can't get one there, go to your user manual and find the parts list, then order your replacement...if you don't have your user manual you can go to the grill maker's website where they will have links to part lists for your model grill.
Posted on Sep 07, 2009
  • bulldogchief
    bulldogchief Sep 09, 2009
    You can still look online at the Char-Broil website and/or the Home Depot website, Lowe's website, etc.
    If you give me the make and model number of your grill, I may be able to direct you to where you can get the replacement parts.
On my ifs40 imperial fryer the pilot knob just spins around and wont send gas up to pilot orifice when i push it in
There is a little tab on the knob that is broken. Replace the knob and the fryer will work. One center screw holds the knob on the valve.
Jul 19, 2016 | Imperial IFS40 Deep Fryer
KNOB to controll heat level is broken.
Mike what I do if Knob pin that move the pilot pin down on gas vavle is broken there no replace part# for it. You got replace gas control valve at a tune of $180.00. What I've done for last 20 yrs is drill hole thru the knob at extach locate broken pin then place # 8 screw inhole with nut on bottom of knob and on top . Use the two nut adjust the length screw as need. Work good done it maybe 30 to 50 times.
Jan 22, 2011 | Desa International CBN20T Heater
The knob for the air pressure regulator is broken. what should I do?
You can get a new knob sears it vary good about parts lists as long as the steam for the regulator it good. Or you could ever retrofix with something that fits and you can turn the valve with as long as it works it dosen't matter what the knob looks like.
Dec 28, 2010 | Craftsman Air Tools & Compressors
How do I replace a broken stem on the griddle knob of a forty-eight inch Viking range?
You would remove all of the knobs and then you remove the screws holding the face panel on there. Then you can access burner valves. The new part may not come with a preset orifice because the factory does not know which type of gas you have. So what they do is tighten the orifice all the way down. Lets see if I have a viking service manual:
Viking Stove Manual
Viking parts outlet
Oct 29, 2010 | Viking Kitchen Ranges
Solis Palazzo steam valve knob spins and will not close valve all the way. Knob seems to be stripped.
There is a pin on the valve the knob fits in. The pin might be broken. You probably just need a new valve.
Sep 23, 2010 | Solis Palazzo Espresso Machine
Dead burner on kitchenaid gas cooktop?
it is strange that you have no gas and no spark! if you held a match to the burner and turned the burner valve on it would lite di spite a failed ignitor,but for it not to lite, the burner valve[its what the knob attaches too] would have to be blocked[thats rare]or ........i got it .....the knob is broken.thats the only thing the burner valve and the spark ignitor have in common.try a knob from another burner................again.you have spark,because others are working.spark on troubled burner would work if valve blocked at orifice outlet,and if spark failed you would still get gas they work independent of each other,[but in unison].thats why im thinking knob.its the item that works both .when you turn the knob it opens the gas valve and as the gas valve rotates by turning the knob it activates or turns the spark switch so it closes the curcit allowing the electricty to the spark moduel.hey i hope that helps a little. God bless ,tom
Feb 13, 2009 | KitchenAid Cooktops
Vulcan fryer gas control knob will not turn
700 SERIES GAS VALVE MUST BE CHANGED COMES WITH NEW KNOB PRICE OF GAS VALVE IS ABOUT $105.00
Nov 16, 2008 | Vulcan EF3 Deep Fryer
I have a dayton furnace with a honeywell vr8440p-2088 gas control. The ignition works fine but the problem is I am getting no gas it seems to light the pilot. I checked the orifices at the end of the pilot...
I had the same problem with the same honeywell vr8440p2088 gas controler.  I found out the nob to turn on the pilot was broken.  If you can pull the knob off it is broken.  The knob has two small teeth on it to keep the pilot and gas open.  good look finding a replacment knob as the part is not made anymore.  But there is a relacement part for it.  it just costs about 250.00.
Apr 18, 2008 | Honeywell Heating & Cooling
Jenn Air gas cooktop
pop me an email at b4829@yahoo.com and reference your cook top you can rate me later
Mar 29, 2008 | Cooktops
Grilling Logo
159 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
