Question about Car Audio & Video
2003 jeep rubicon relay resistor instllation location.
Location of relay resistor for air conditioning on 2003 jeep rubicon.
    Guru:
  • 1,326 Answers
You have this posted in car amplifiers. But mu guess would be behind the glove box or behind the heater controls.
Posted on Sep 14, 2009
Is the overdrive switch the same in a 2003 jeep wrangler & 2008 jeep jk
same , as in location
or same as in , same gear ratio?
and there are many submodels of jk, like rubicon?
what is your concern?
May 22, 2014 | 2003 Jeep Wrangler
I have a 2008 jeep rubicon that the headlights the indicator lights the wipers and air condition stop working the same time
LIGHT INDICATOR AND WIPER ALL PART OF YOU SWITCH ON THE STEERING COLUMN .BUT FIRST READ YOU MANUAL AND CHECK ALL THE FUSES.INSIDE AND OUTSIDE THE JEEP.NEXT FOLLOW THE GROUND WIRE FROM THE BATTERY AND MAKE SURE THE WIRE IS CLEAN AND TIGHT TO THE BODY.MORE GROUND WIRE WILL FIND UNDER THE DASH BOARD CLOSE TO THE DOOR HINCH.
GOOD LUCK
Mar 27, 2014 | 2008 Jeep Wrangler Rubicon
Check engine code 55 jeep grand cherokee laredo v6 1997. transmission wont shift properly also pulling code 21 and i figured out that one is for the throtle position sensor
These are the fault codes for your Jeep below;
Jeep
11 IGN reference signal.
13 Fault in the map sensor pneumatic circuit.
14 Fault in the map sensor electrical circuit.
15 Fault in the vehicle speed sensor circuit.
17 Engine running too cool.
21 Problem in the oxygen feedback circuit.
22 Fault in the coolant temperature sensor circuit.
23 Air temperature sensor.
24 Fault in the throttle position sensor circuit.
25 Fault in the IAC motor drive circuit.
27 Fault in injector driver interface circuit.
31 Purge solenoid circuit.
33 Fault in air conditioning cutout relay circuit.
34 S/C solenoid circuits.
35 Fault in fan relay circuit.
41 Fault in the charging system or no field current.
42 Fault in the ASD relay driver circuit.
43 Fault in ignition coil control circuit.
44 Battery Temp Voltage.
46 Battery voltage is too high.
47 Battery voltage is too low.
51 Lean condition is indicated.
52 Rich condition is indicated.
53 Internal problem in module.
54 Fault in the distributor high data rate pickup circuit.
55 Completion of fault code display.
62 Unsuccessful attempt to update EMR mileage.
63 Unsuccessful attempt to write to an EEPROM location by the controller.
76 Fuel pump resistor by-pass relay circuit
Mar 08, 2011 | 1997 Jeep Grand Cherokee
How to replace horn relay on 2007 jeep wrangler
The horn relay is located in the Intergrated Power dist Box, This is a Cherokee, but you get the idea.
Jul 23, 2010 | 2007 Jeep Wrangler Unlimited Rubicon 2...
Where is the air conditioner blower fan relay on 1996 Jeep Grand Cherokee located?
The blower fan relay is located in the fuse box on the driver's side fender-well. A Jeep Cherokee uses an electric fan as an auxiliary fan for engine cooling and for cooling the air conditioning condenser when the air conditioning is in operation. A radiator temperature-sensing switch that activates the fan relay at 198 degrees F turns the fan on and controls its operation. The temperature drops when the vehicle is in motion and the switch turns the fan off. When the air conditioning system is in operation, the air conditioning relay supplies power to the fan relay via a fan diode downstream from the ignition switch. This diode activates the fan relay and keeps the fan operating as long as the air conditioning is on. Thanks. you can rate this solution and show your appreciation.
May 18, 2010 | Cars & Trucks
I have a 2006 erangler X And the heater fan control low speed does't work. I dont know where the resisters are. Need help!
They are near the blower motor as the air is used to cool the resister, usually on the bottom of the blower housing.
Mar 30, 2010 | 2006 Jeep Wrangler
Have a 2003 Jeep Wrangler, Rubicon and the hear/AC blower fan only comes on in the high position. The other setting low, med and med/high the blower will not come on. Is this the controller it self?...
The problem usually stems with the blower motor resistor,high speed by-passes it and there-fore the controller is sending power but the resistor has gone open and the speeds can't be regulated.
Feb 08, 2010 | 2003 Jeep Wrangler
Faulty speed sensor on a 2004 Jeep Rubicon
The speed sensor is located on the left side of the transfer case extension .
Apr 29, 2009 | 2004 Jeep Wrangler
Car Audio & Video Logo
69 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
