Question about Whirlpool AWM5145/2 Front Load Washer
Wirpool awm5145/2 hi when i select a program it clicks once then nowt else if you give it a slight helping hand still nowt not even a noise from motor only near end of cycle from pump it starts to work.
  • ruralfinca Sep 08, 2009
    hi sorry i didnt explain correctly.when a program is selected it clicks then nothing else.even if it is left for 1/2 hour nothing timer doesnt move, cheers.
  • ruralfinca Sep 09, 2009
    hi thanks for your answer, the machine is a wirpool awm5145/2 and the service number is 857051415300.hope this helps cheers kevin.
  • 11,896 Answers
Sounds like pump is working and motor is not. You will need to test the pump and voltage to the pump. A faulty selector switch or lid switch will also cause non working problems. Go to this site to see what I am talking about.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Posted on Sep 09, 2009
  • 15,935 Answers
The timer/control module is obviously faulty.
Please use the "continue with this expert" option and reply with a verification of the model # in question.
Is it AWM5145/2 as noted in the subject selection?
Then I can help you to locate a replacement part.
Thanks
Posted on Sep 08, 2009
  • 3,230 Answers
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
One test to try would be to remove the agitator and then put the machine into spin mode. Does it make that noise you spoke of? I guess here, that this is a somewhat uncommon gearcase problem with stripped gears inside. That's a wild guess. You would almost have to look at the clutch to see what it is doing. When in spin, if the clutch is making some wild jerking motions, then the gearcase
needs to be replaced.
Thanks
What is making creaking squeeking noises in power chair?
hi, that noise can be caused by the seat mount moving slightly within the seat holder, because it 's a tight fitting when it does move slightly , you get the noise...only needs mm amounts of movement, Careful spraying WD40 in the gaps will solve this but take CARE making no electronics or electrics are near...disconnecting one battery will be ideal..
a visual inspection of all of the bolts and nuts should prove peace of mind...
WARNING: You need to tip over the power-chair to carry out the instructions set out below so extreme care is required.
This noise can also be caused by the motor gearbox ,, carefully place your hand on the gearbox as someone powers the chair , can you feel a grinding sensation ? , bear in mind you will get some feeling there of a dragging.
Regards
Rob
www.gewizrepairs.co.uk
Oct 10, 2014 | Pride Mobility Jazzy 614 - Jazzy Blue,...
Hi, I've just got myself a Grand espace and have a problem with the roof, the sun shade opens fine but when I switch to the roof It moves slightly and then a load clicking noise starts, is my roof stuck as...
there is a gear on the motor they do wear out. try to give it a hand a few times if it makes a crunching sound wile you giving it a hand the the gear is warn out.
Oct 13, 2013 | Cars & Trucks
Dryer has stopped spinning was making a slight wooing noise but will not spin, i can spin it manually by hand but will not spin when plugged in
You need to check the power to the motor when the dryer is started, if there is no power then the program controller is a suspect and must be checked.
If there is power to the motor - motor warms up then the capacitor to the motor must be checked.
Jul 02, 2011 | Dryers
My microsoft is not opening, they said that l should use the control panel to repair it
They're partially correct. What you need to do is open Control Panel and choose Add or Remove Programs. Scroll down to Microsoft Office 2007 and select Change (NOT Remove). A window should open that gives you the option to Repair. Select that option and it should resolve your issue.
If your using Windows 7 it's a slightly different process. Open Control Panel, click Programs and Features, then select Office 2007 and select Change. Once again choose Repair and you should be good to go.
May 04, 2011 | Microsoft Office Professional 2007 Full...
Clicking noise under hood - have repaced alternator belt and pulley
i dont want to alarm you but you really need to check into this. the only 98 explorers i have heard with clicks have led to timing chain slider failures which is not a good thing,it was cheaper to buy used motor than to repair. go have it checked out or while the motor is running put your hand on top of valve cover on the rear pass side and feel for clicks or small taps or knocks while reving motor slightly. and repeat on the driver side front of engine. and i sure hope this is not your clicking noise location.
Jan 08, 2011 | 1998 Ford Explorer
When I turn the cycle control knob it no longer makes a noise
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
fg
May 30, 2010 | LG DLG7188 Gas Dryer
My dryerr is making a noise like rattle I know nothing about dryers but maybe a belt or motor?? I have an electric dryer. .
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 13, 2010 | LG DLG5932W Gas Dryer
Select a program , i makes the normal noise , but nothing happens
Hi did you find a solution? as mine has just started doing exactly the same!
May 15, 2009 | Hotpoint WMA46 Front Load Washer
Avaya 18D unable to make outgoing calls
Sounds like you changed your line selection. Changing line selection on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
enter **
press the lit line in the order you want the to be used, i.e. line 2 then line 3 then line 4 etc.
enter ** when finished with line selection
Press feature "00" to logout
Hope that helps
Mar 20, 2009 | Avaya Partner 18D Display Phone (315807BA)
Whirlpool AWM5145/2 Front Load Washer Logo
118 people viewed this question
Dan Webster
Dan Webster
Sal De
