Question about Dell Dimension 4600 PC Desktop
Hard drive and cd drives still on
My problem is this, when I shut down Windows XP on my Dell Dimension 4600 computer it shuts down fine. But about 10 seconds later the power led flashes off and on and the hard drive and cd drives keep intermitingly spin off and on. What is causing this? Power Supply? Mother Board? Please help!
Thanking you in advance.
Chris.
  • sazook Dec 13, 2007
    I figured out the problem. The Network (integrated on motherboard) seems to be the problem. A friend told me to disconnect the network cable before I turn off the computer. He said if it stopped, then it was something to do with the Lan/WOL. I did that and it turned off and no whirring or powering up like symptoms. Because it is a Dell Dimension, there are no settings for the Wake Up in the BIOS. What can be done? Should I just install another Network Card via PCI?? Will that solve the WOL/Wake up thingy?? Thanks for all your help so far. Nothing like a computer problem to drive me to the nut house.
    Thanks
  • 43 Answers
As a Dell DCSE, the majority of problems I have seen in the Dimension & Optiplex line has been in the power supply.
What you describe sounds like the 5V line shuts down but the 12V does not (what keeps the drives spinning). I would definitely vote for a power supply in this case as it sounds like the system board is telling the supply to power down, but it is only half listening...
Since your model is probably out of warranty (more than a year old) you can pick up an aftermarket part for less than $40, shipped.
Here is a link to the service manual:
http://support.dell.com/support/edocs/systems/dim4600/en/4600/sm/index.htm
If you need any help finding the part, let me know. Be sure to include Reply with the Service Tag to expedite the matter.
Hope this helps...
Posted on Dec 09, 2007
  • 108 Answers
Locate Power Wakeup option in modem/LAN in BIOS and disable them, if you have "power wake up" enable for LAN/modem your computer will be switched on for remote network command.power wake up setting are located on BIOS.
Dimension 4600 dvd drive keeps opening
Try this first - open up the BIOS part of the system. To do this, shut the computer off; wait at least 10 seconds; turn the computer back on and then press F2 when the Dell logo appears. Press continually until the message Entering Setup appears. In the Boot Order section, remove the CD/DVD drive from the boot order by clicking on Disable from the drop-down menu. If this doesn't fix it, please resubmit your question
Feb 19, 2015 | Dell Dimension 4600 PC Desktop
When trying to reinstall windows xp, the process keeps failing during setup saying, "The file comct132.dll was not copied correctly. The file Setup on your hard drive is not a valid Windows XP system...
Click start/run Type: cmd
In the Command window type:
SFC /scannow Note the space between SFC and /scannow
You can copy/paste: SFC /scannow
Hit the Enter button
keep your xp cd handy in case you're asked to chuck it into your cd rom
The above should replace missing files and get you to the place where the install can proceed.
Let me know. __________________
If this doesnt work,yes hard drive needs to be replaced.internal hard drives are system specific.u need to contact dell tech support to get the right specifications
Sep 17, 2010 | Dell Dimension 4600 PC Desktop
Dell Inspiron 1525, wouldn't recognize the hard drive. Put in a new hard drive, worked fine for a month - now same problem.
tell me the age of your system first. and before that, just try re installing your operating system completely ( genuine windows xp or vista recommended) and if the problem still persists...get back me @ deepuunni1985@gmail.com
Aug 22, 2009 | Computers & Internet
Computer won't shut off (occasionally)
usually this the indication of Hard driver problem.
this hard drve is on its last lag. it is hardware failure.
get a new Hard Drive and copy everything to the new hard drive. save this one as a backup.
May 22, 2009 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 stalls during boot
Turn the computer's power on.
Immediately put the original Windows XP CD into the drive.
Tell the computer to boot from the CD (not from the hard-drive).
Does it start to boot from the CD?
Do you get as far as the "repair/install" boot-screen?
If so, your basic hardware is OK, and turn your computer off,
rather than choosing "repair" or "install".
Then, it's probably either the hard-drive that is failing,
or the installed copy of Windows XP is fuddle-duddle-ucked up, so that it cannot finish the "Windows startup" processing.
Apr 23, 2009 | Dell Dimension 4600 PC Desktop
Multiple viruses on a Dell Dimension 1100
Formatting your hard-drive is the easiest way to eliminate anything on that hard-drive. Follow my steps below to do just that.
Start your computer so you can open the CD-ROM drive. Insert the Windows Installer into the CD-ROM drive. Close your CD-ROM Drive. Shut down your computer.
Now start your computer and while your system starts up look for an option for the, "Boot Menu" or, "Boot Device." It will have a key associated with it that you have to press continually for you to enter the menu. For instance:
(F8) Boot Menu.
Here's a hint to help you out. If you see the loading screen of your operating system, you've missed your window. Restart and try again.
Now just to clarify, we're not out to change the boot sequence, we're trying to boot from a specific device. Once you find that menu select your CD-ROM drive and press enter. It might ask you to, "Press any key to boot from CD-ROM drive." As it mentioned, press any key. Afterward the Windows Installer will launch.
Follow the directions on the screen to set up Windows. Yeah, it will warn you that there is another OS installed on your primary Hard Drive and that it might be better for you to, "Repair" your system. Ignore that and continue with the process to Install Windows. Before the final step to install Windows there is a screen that allows you to partition your hard-drive. In this are, erase ALL partitions. Afterward create a new one which will be your C:\ drive. If you want to partition your drive further, go ahead. However, at this point you can continue the Windows Installation and the Installer will ask you if you want to format with the NTFS or FAT32 type. Format with the NTFS type.
Now the Windows Installer will erase EVERYTHING on your hard-drive and proceed to install Windows XP.
Feb 06, 2009 | Dell Dimension 1100 PC Desktop
Pulsating hard drive on startup and off
To eliminate a software problem, I installed another hard drive with the same operating system, and the problem still existed.
I also flashed the BIOS with no results.
The most logical conclusion is that the problem lays with power supply.
A new power supply was ordered today.
Jan 13, 2009 | Dell HP-P2507FW Power Supply ** FREE...
Dell dimension 4600
check in the bios that it is your new hardrive it is seeing, and not your old one still sitting in thr bios memory, as taking out the battery doesnt always delete the cmos memory.
There shoul be an option in the bios to auto recognise the drive
Aug 24, 2008 | Dell Dimension 4600 PC Desktop
Can't reboot windows cd on with cd drives
If you have it available, boot to the Dell DImension Resource CD and run the diagnostics on the hard drive. From the description of you problem, you may have a failing hard drive.
Other things to check:
1. Ensure the system BIOS (F2 at boot) sees the hard drive and has the correct date and time. If the motherboard battery is failing, the time and date will not be retained when system is powered off.
2. If you are able to format the hard drive, but the windows XP installation process gives you file copy errors, then you may have a bad RAM module. If the system has 2 or more modules, take out all but 1, retry the install. If you get file copy errors again, try a different module.
3. If the Hard drive passes dieagnostics, but fails to complete a format, replace the hard drive.
Jun 01, 2008 | Dell Dimension 4600 PC Desktop
Hard Drive
Put the CD in your CD Drive and shut off the pc. Then start it up again making sure the CD is still in the drive. You will then be asked if you want to boot from CD. Press any key to confirm this (it might skip asking you if it detects that your hard-drive is already blank) Then you want to let it run its install routine. Im not sure what options it will give you but the ones you are looking for is FULL install.
Aug 31, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
