Question about Cobra FRS 307 (14 Channels) 2-Way Radio
Looking for a schematic so i can trace the power
The unit will not power up. i took it apart and read the voltage on the back side of the battery compartment and got good voltage. i also worked the switch and it clicks but i dont have a schematic to help me trace the power. does anyone have the schematics?
    Scholar:
  • 66 Answers
GO TO THE FCC WEBSITE:
https://fjallfoss.fcc.gov/oetcf/eas/reports/GenericSearch.cfm?calledFromFrame=N
ENTER THE FCC ID # YOU MUST ENTER IT CORRECTLY.
FOR INSTANCE...MY FCC ID # IS G9H3-5810 ENTERD CORRECTLY WOULD BE ON THE FIRST LINE
G9H AND THE NEXT LINE 3-5810.
TRY THIS FIRST UNTIL YOU GET USE TO IT AN IT WILL BRING UP ANOTHER MENU. UNDER DISPLAY EXHIBIT CLICK ON DETAIL
THEIR YOU WILL SEE BLOC DIAGRAMS,SCHEMATICS ETC. HOWEVER NOT EVERY RADIO WILL DISPLAY THIS,IF THE COMPANY PAYS EXTRA $ TO THE FCC CERTIAN THINGS WILL NOT BE DISPLAYED LIKE SCHEMATICS.
THERE IS A WAY AROUND THIS ALSO, THE US PATENT OFFICE. TYPE IN THE PANTENT NUMBER AND EVERYTHING WILL BE DISPLAYED, IF YOU CAN FIND THE PATENT ID #.
HOPED THIS HELPED
KEVIN
Posted on Dec 30, 2007
Maytag gas dryer model SDG4606AWW timer wont rotate on any cycle, dryer just keeps running until knob is rotated manualy to off, replaced timer and new one is doing the same, took dryer compltley apart,...
I don't have a Maytag schematic handy but there should be one on or in the dryer. Trace the clock wiring back until until you get voltage. I am betting one leg of the time motor goes to the drum motor (Gray wire maybe) and the other leg to the dryness sensor module (brown wire). Check these wires against both Line and Neutral. That should tell of it's the module or the motor block.
Nov 04, 2013 | Maytag Dryers
93 flhs. evo, bike just quit running. no spark at plugs, put in new plugs,wires and coil. still no spark. i have a crane H1-4 in timing cone. is that my problem. would like to be sure that is problem...
If your bike has been converted to a Crane ignition, all you have is the Crane unit, two spark plugs, two wires, and a coil. Seems you've replaced everything else so the unit is all that is left.
Now, before you replace the unit, you see there are two wires on the hot side of the coil. Make sure you have battery voltage to that side of the coil. A test, take your plugs out and lay one on the engine where you can see it. Turn your ignition switch on, then turn it off. You should see a single spark when you turn the switch off. If so, you're electrical wiring and coil are alright. Your unit is bad. If you don't get a spark, you are not getting voltage to the coil for some reason.
If you are not getting power to the coil, make sure the "Run/STOP" switch is in the right position. If it is, you'll need a schematic to trace the voltage back to the source. I have a schematic for a FXDWG. If you want a copy, send me a personal e-mail at wd4ity@bellsouth.net and I'll send one to you. This forum will not allow for a file over 150Kb. Remind me of what you need.
Good Luck
steve
Nov 07, 2010 | Harley Davidson FLHT Electra Glide...
My DC616 a straight 16 gauge DeWalt finish nailer tries to drive 2 nails when it fires 1 out of about every 5 to 10 shots. I am a finish contractor and have used this nailer for about 6 years. I was...
Argh...
Had the same problem, but only after about 4-5 nails. Once it jammed 4 times in a row - very frustrating.
I read the manual, took the unit apart, checked the driver - it was straight. I took a file and filed the back end of the driver down a bit so it would miss the second nail and so far it seems to be working famously.
Great unit...
Sep 07, 2010 | Dewalt DC616 16g Cordless 18v Straight...
I have a 96 ford explorer I just replaced the battery and the alternator in it. When starrted the battery lite stays on and the alternator does not charge it. Is there a linkable fuse or something I am...
Trace all of the wires that are attached to the alternator. If there is a fusible link or a broken wire you will find it. If the alternator is charging but something else is wrong the alternator will pull a steel wrench toward it. You did not mention the voltage regulator. You will find it when tracing your wires. Look it over carefully. Voltage regulators fail keeping the alternator from working. Parts stores have regulators and they are easy to install.
Mar 21, 2010 | 1996 Ford Explorer
Casio CT-670 Tone Bank keyboard completely dead
How familiar are you with schematics? I've just found my CT-670, There where marker marks on the keys. I cleaned it up. I took it apart as one channels had no sound. I love this machine. I want to find a manual for it also schematics would be very helpful for me too.
I would suggest looking inside for burns on semiconductors. or loose soldering. I need to replace a chip that has no cross reference... that I've found yet... I think it's an amplifier but need to spend more time on it....
Mar 14, 2009 | Casio Music
NO PICTURE BUT I HAVE SOUND 42" INSIGNIA/PRIMA
I just repaired the TV.. It's the main power board that's causing the problem.The biggest board in the TV. I took a metre to the old board and it's failing on the VS circuit. I was only getting 14volts when i should of been getting 78 volts or something like that. If you look on aluminum backing of the screen .. top right corner there's a sticker which tells you what the voltages should be for the VS and a few others. It's the 10 pin socket top left corner on the main power board. VS is the first 2 pins. That's the part of the cuit that caused the screen not to light up. I had audio and power but no picture. All the other readings I took were normal on the board that was failing. Only the VS reading failed with the 14 volt reading. I put in another a good used main power board and took a reading from the VS pins and it was normal. I connect the cable to the y board and the TV powered up and is displays fine. If there's someone who does work on low level cuits and finds the actual part that is failing I would like to know. I replaced my board with a known good one and traced it too which part of the cuit failed. I suspect it's just buying time and don't plan on spending another $100.00 on another board after this one. So any help would be great. Thanks for all Craig
Oct 08, 2008 | Insignia 42" LCD Flat-Panel HDTV
Altec Lansing ADA995 does not work
This is my Dell Altec Lansing 5.1 (ADA995) surround sound amplifier for my computer. There is a design flaw where the board gets corroded due to the fact they caulked or glued it togther and left some of the circuit board hanging out. Just thought I would point out my findings in case some of you had the same system. It's a relatively easy fix. I got all the parts from Newark for about $30.00, and it took roughly 2 hours. Original Amplifier Chips below:
Positive Voltage Regulator is blown out:
Notice the traces where corrosion caused a short:
Another view of the burnt traces:
The glue or caulk ran straight across here:
This resistor was blown out.
I pulled it out before I took the picture I went ahead and replaced all of the 4.7 ohm 1/4 watt resistors:8_18_2012_3_31_59_am.jpg
Blown out 4.7ohm 1/4 watt resistor:8_18_2012_3_32_37_am.jpg
Just before surgery on the amp chips:
Re-jumpered the traces:8_18_2012_3_35_55_am.jpg
Re-jumpered the traces:8_18_2012_3_36_44_am.jpg
New amp chips are in! Boy that "Heat Sink Transfer Paste" is really messy!!!:8_18_2012_3_37_26_am.jpg
A peek at the underside:8_18_2012_3_38_11_am.jpg
New L7815CV Positive Voltage Regulator (Shown here):
New L7915CV Negative Voltage Regulator is on the back side:8_18_2012_3_39_35_am.jpg
New amp chips are all nestled down in their new home!:
Boy that's a big heat-sink:
Time to try it out. And it works. Boy, going a week with out 5.1 audio on your computer is terrible! Nobody should have to live that way or be subjected to that kind of torture. I guess this would be considered a "first world problem"!
-Jason-
Aug 20, 2008 | Altec Lansing ADA995 Speaker
19tvr60
first try another remote.and play back try a vcr tape head cleaner. by 3m in a red case. those work.
Jan 10, 2007 | GE 13TVR60 Combo
Cobra FRS 307 (14 Channels) 2-Way Radio Logo
544 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
