Question about Filter Queen Majestic Canister Vacuum
I need a wiring diagram & detailed specifications for my Filter Queen Majestic limited edition.
  • 430 Answers
Open the vac by removing 3 screws below the handle area and the long screw at the bottom of the cone. If the motor has been removed, you will have 2 motor leads , 2 power head socket leads, and 2 switch leads as well as the cord. Do not twist your wires first when pairing, twist with the wire nut ony and tape afterword as there is metal nearby in the housing area
1 side of the cord goes to the switch only. The opposite side of the switch will go to 1 of each of the motor and Socket. The remaining motor and socket leads pair with the remaining cord lead.
While you are in there change the round filter dic covering the front of the motor and you could change the foam/ felt wrap around the inside of the housing.
There is a insulating disc at the top of the motor to prevent shock between motor and screen. Do not remove it.
Posted on Sep 08, 2009
Where do I purchase bearings from in New Zealand for the Filter Queen Majestic
Hi and welcome to FixYa, I am Kelly
The do not list bearings on their website but you should be able to get them via contact / request information using this link:
http://filterqueen.co.nz/contactus.php
Postal Address: Clean Air Solutions Limited PO Box 56324 Dominion Rd Auckland 1446
May 04, 2011 | Filter Queen Majestic Canister Vacuum
How often is it necessary to change the filter one on a Filter Queen Majestic?
The best thing to do to both, keep your Majestic suction and air flow strongest, and keep from pulling dirt & dust from being pulled past the filters which can cause damage to the motor, and charcoal filter, replace the filter once a month. If you use it longer than that it will both loose suction and will cause your Medipure or Enviropure "charcoal" filters to wear out prematurely. Mark the change date right on the filter or on your calendar to help keep track.
Dec 20, 2010 | Filter Queen Majestic Canister Vacuum
Got a Filter Queen Majestic Limited Edition, the one with the high and low power switch, an I have to change the power cord. How can I open the main unit to reach that power cord? Thanks,
first remove the top cap under your handle.
Then, remove the three screws under the handle.
remove the rubber cover on the switch
undo the clamps on the side of the unit
lift off the chrome cover with the cord on it by the handle itself.
When you have the access there, change the filter inside the upper chamber as well.
Good luck
Nov 15, 2010 | Filter Queen Majestic Canister Vacuum
I was given a filter queen majestic limited edition but have no manual, can you help
This is a very straight forward good quality vac, with excellent filtration.
The cannister has two large clamps to release the motor from the dust chamber. Depending onb the age you may have an LED which comes on when it is time to empty the vac. The cleanest way to empty is to leave the paper cone over the dirt and carefully tip all into a garbage bag sitting on the floor.
You should replace the paper cone with a genuine fresh one each time you empty the container. In addition there is a paper disc inside the motor housing which you will access by removing the flat screw at the bottom of the plastic grille cone.
Sep 03, 2009 | Filter Queen Majestic Canister Vacuum
Need Filter Queen Majestic Owners Manual
I downloaded and printed a Filter Queen Owners Manual from the Filter Queen.Com website. It was hard to locate on their website, but I printed it free.
Dec 01, 2008 | Filter Queen Majestic Canister Vacuum
Filter Queen Majestic Canister Vacuum Logo
685 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
