Question about Amana Washing Machines
The gears are turning but the belt is not is my belt bad
  • 574 Answers
If motor is turning and motor pulley and the belt isn't moving it could be broke belt but does the belt look loose or is it loose make sure it has tension on the belt
Posted on Sep 07, 2009
93 Toyota 1hz hzj80 Replaced diesel fuel pump but had to take timing cover off due to oil leak and fuel pump gear fell out Reassembled and lined up the gear but got to stage of putting belt back on and...
The pistons are hitting the valves due to wrong alignment of timing gears and the timing belt. Align the timing gears and timing belt marks according to the following diagrams.
Good luck.
Mar 08, 2014 | Cars & Trucks
Blows breaker and groweling noise
It sounds like the motor is bogging down due to bad bearings or something is making the shaft too hard to spin. Make sure all the spindles are free. If its happening under load, make sure the lathe gets up to speed before trying to make any cuts.
Oct 18, 2012 | Ammco Combination Disc/Drum Brake Lathe
2003 sebring will not turn over
PProbably a bad starter gear teeth or a bad ring gear teeth on the flexplate/flywheel.
May 22, 2012 | Cars & Trucks
1994 dodge caravan was making a noise in the area of the serpentine belt....the belt has since broke..what noise like a gear grinding would be associated with this?
Could be bad bearings in the belt tensioner pulley, bad bearings in the water pump, bad bearings in the alternator (though that would tend to squeal unless they're really trashed) or bad bearings in the power steering pump.  Get a wrench on each one and see which one won't turn.
Apr 25, 2010 | 1994 Dodge Caravan
Motor turn over but rotor stays still inside the distributor cap
its either a broken timing belt ,or bad gear on the bottom of the distribtor!!
Mar 22, 2010 | 1990 Volkswagen Jetta
I put on a new timing belt.both cam gears marks are up,crank grear mark is in line,will not start.
the arrows should face up and there are marks on each gear that should be across from one another in between the two gears{were the gears are nearest each other} al marks should line up again after you turn the crank two complete revolutions. if not remove belt and redo. also make sure cam and crank sensors didnt get damaged/uunplugged
Mar 20, 2010 | 1998 Dodge Stratus
MY CAM BELT IS BAD IS THAT BACK THE GEAR ON THE
thats the balancer shaft gear, its LOCKED UP??? thats bad, never had that happen. a shop that does a lot of HONDA work should look at that for you, the engine may need to come out. sorry for the bad news ; (
Oct 20, 2009 | 1996 Honda Accord
Car is starting but not turning over
if the timing belt is not turning than either your starter is bad and not throughing out the start gear or the flywheel is bad and not recieving the startere gear to turn the motor over. because the timing belt should spin when turning the eng. over...
Jul 31, 2009 | Plymouth Reliant Cars & Trucks
Washing Machines Logo
46 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
