Question about Dishwashers
Dishwasher does not clean dishes very well
I just moved into the house and the dishwasher does not clean very well. Even when I was wash the dishes with very hot water.
Any ideas on how I can diagnose the problem?
  • 432 Answers
Make sure that the drain hose does not have a restriction.Sometimes the hose is blocked with old food that is to large to get out.Also. try removeing the hose from its drain connection under your sink.Have a empty bucket to catch the water.And rags. Where the hose connects make sure its not blocked at the sink.If the drainage way is totally cleaned out and it still does not work good then its possible that the water pump in the washers is weak. I hope this helps you.
Posted on Sep 07, 2009
Jennair dishwasher: how do I clean out the drainage screening, etc.?
some dishwashers use salt to soften the water used in the washer , so check that the grit is not undissolved salt particles
down load an operators manual from google search
Oct 01, 2016 | Dishwashers
Frigidaire 24' doesnot clean the dishes after complete wash cycle. sometimes it seems as if the top rack does'nt even get wet please advise
ron singh, Have you just moved in to this home? I recently had this same problem.is your water from a well? or is the city water from a well.I just moved from the big city to a smaller suburb out the city. The water in the new place is extremely hard. all of our silverware and glasses had a coating on them. The heated dry cycle made even worse. we had to install a water softener for the whole house. This also helped in the showers and washing machine. The film will go away after softener is installed. There is nothing wrong with the dishwasher.
Hope this helpsJoe Connolly
Nov 12, 2011 | Frigidaire Dishwashers
Please help! I just moved into a new house where the Frigidaire dishwasher worked great for 2 weeks. Now, it's leaving hard salt-like granules all over my dishes and not rinsing all the food off. ...
Your dishwasher has clogged water ports.
Start the dishwasher with NO dishes in it.
Once it starts the wash cycle,open the door and pour in 1 quart of WHITE vinegar and resume the wash cycle.
That should clear out the residue.
Change your dishwasher soap to the FINISH brand name for happy clean dishes.
Apr 28, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
Dishwasher just started leaving food residue on dishes after washing. We usually don't rinse beforehand but even when we do this it's still happening. Can I run something thru a cycle to give the washer a...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Mar 08, 2010 | GE Nautilus 24" Built-in Dishwasher
Kenmore 17033 dishwasher will not clen dishes
USE JET DRY and clean the system every once in awhile by running it through a cycle with no dishes and use washer cleaner for that model.
Jan 07, 2010 | Kenmore 24 in. 17033 Built-in Dishwasher
Our dish seem dirty after a wash we have cleaned the filters
turn it on to run it with out dishes but instead of soap use house hold viniger to clean the watter jets thats what keeps the washrer from cleaning well
Oct 26, 2009 | Belling 24 in. IDW603 Built-in Dishwasher
Dishes not clean
It MIGHT be a bad "impeller". This is a little propeller-like device that chops up chunks of food and in some cases performs part of the pumping action of the water. Not an expensive part, but sometimes a pain to replace.
Sep 04, 2009 | Maytag MDB5100 Dishwasher
Dirty dishes
You need to take the spray arm off of the bottom and get down to the filter: there's probably food trapped in the filter somewhere, not able to drain out and it keeps recycling onto the dishes at each cycle. Good luck!
Jul 17, 2008 | Sears 24 in. 14181 Built-in Dishwasher
Crusty stuff on glasses after wash cycle
I never figured out what caused this problem. I cleaned it and took it all apart, could not find any debris lodged anywhere. However, I solved this problem! I now only use Cascade Complete dishwasher detergent. Has to be the "complete" version of Cascade. No more grit - nice clean dishes now and sparkling glasses.
Jun 01, 2008 | Hotpoint 24 in. HDA2000Z Built-in...
Dishes not clean
If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Apr 04, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishwashers Logo
66 people viewed this question
Top Dishwashers Experts
