Question about Lutron ELECTRONICS CO. Q-603PH-WH "QUOTO" 3 WAY DIMMER
I have installed the master and slave and i cannot get either switch to work
  • ffornari Sep 07, 2009
    ive installed lutron dimmers in 2 locations for the same light and cant get them to work
  • 15,935 Answers
  1. The first thing you will have to realize is that you can only replace ONE of the existing three-way switches with a three-way dimmer switch. If you try and replace them both, the circuit will not work. Therefore, choose to replace the three-way switch that you will probably use the most to control the lighting.
  2. Step 2 Find the circuit breaker that is delivering the power to the lighting circuit and toggle it OFF. Flip each three-way switch to make sure the circuit is off.
  3. Step 3 Remove the cover plate from the switch and remove the two screws securing the switch to the wall box.
  4. Step 4 Gently pull the switch out of the box by pulling on the top and bottom tabs. Do not touch the sides of the switch. With the switch out of the box, use your voltage tester to ensure that the circuit is truly off.
  5. Step 5 Take a moment and look at how the switch is wired. One side of the switch should have a single red wire attached to it and the other side should have either two black wires and the ground or a black wire, a white wire with a strip of black electrical tape on it and the ground wire.
  6. Step 6 Remove the red wire and bend it out of the way. Remove the two black wires (or the black and taped white wires) and bend them out of the way. Bend the top wire upwards of the box and the bottom wire toward the bottom of the box so you will know where they get connected on the dimmer switch. Lastly, remove the ground wire and toss out the old three-way switch.
  7. Step 7 Check all of the wires to make sure that they are all in good condition. If any look corroded or weak, just cut off the existing exposed wire and use the wire strippers to remove about 3/4 inches of insulation so you have fresh wire to work with.
  8. Step 8 Connect the ground wire to the three-way dimmer switch first. Then, connect the red wire to the side of the switch with the solitary screw. Now, connect the other two wires to the other side, keeping in mind which one goes on top and which one gets connected to the bottom.
  9. Step 9 Wrap a tight layer of electrical tape around the three-way dimmer switch to protect the terminals. Gently push the wires back into the box and secure the dimmer with the two screws that came with it. Lastly, replace the cover plate with one that properly fits the dimmer molding.
  10. Step 10 Toggle the circuit breaker back on and try out your new three-way dimmer switch!
Thanks for using FixYa!
Posted on Sep 07, 2009
  • 2 more comments
  • blueextc3221
    blueextc3221 Sep 07, 2009
    Lutron has a line that DOES offer Master and Clave controlling possibilities.
    This is called a California set-up.
    More to come....
  • blueextc3221
    please indicate the model # of the switch you are using.
    Is it the maestro?
    And is it a Dimmer SWITCH, or just a Dimmer?
    Model # would be very helpful.
    Thanks!!
    please reply using the "continue with this expert" option.
  • blueextc3221
    CLICK HERE for all the MAESTRO wiring diagrams (depending on your model #)
    CLICK HERE for all the MAESTRO installation guides (depending on your model #)
    Let me know if you need further help.
  • blueextc3221
    The very first guid on THIS PAGE is the one you want.
    Follow the instructions for 5b (2 location control wiring).
    Wiring the Dimmer:
    • Connect the green ground wire on the Dimmer to
    the bare copper or green ground wire in the wallbox.
    • Connect the tagged wire removed from the switch
    to the black screw terminal on the Dimmer.
    • Connect one of the remaining wires removed from
    the switch to the brass screw terminal on the
    Dimmer.
    • Connect the remaining wire removed from the
    switch (note wire color) to the blue screw terminal
    on the Dimmer.
    Wiring the Accessory Dimmer (MA-R, MSC-AD):
    • Connect the green ground wire on the Accessory
    Dimmer to the bare copper or green ground wire
    in the wallbox.
    to the black screw terminal on the Accessory
    Dimmer.
    • Connect the same color wire connected to the blue
    screw terminal on the Dimmer (wire color noted
    above) to the blue screw terminal on the Accessory
    Dimmer.
    Accessory Dimmer.
    Schematics are on the page.
    If you are STILL not getting the light to work - check the bulb :)
    Also be sure all of your wires are stripped back far enough, and your wire nuts are tight.
    Thanks for using FixYa!!
    Sergeant:
  • 338 Answers
Hi ffornari,
please make sure :
- the button cell powering the CMOS data is still in shape
- you have activated both of the IDE channels
in the BIOS and set the drive detection to auto, then ensure the power
plug is inserted correctly and the power supply has enough power (above 250 W) to support all of the drives (including the CD or DVD drive, this can easily amount up to four drives! plus the extra supply for the graphic card fan.., some AGP cards need extra power to run).
try several reboots, as it may take a while for the hardware to detect the drives
- if this still does not work, use a CD or DVD drive as master device
(see jumper settings in the back of it) and hook up the slave disk to it,
set detection to auto again, save settings , reboot.Then hook up second drive as single to the 2nd IDE channel.
Reboot.
You may be lucky now!
Good luck to you
Slave will not open with Master.
switch leads for master and slave to see if its a wiring issue. if the same gate fails to operate, it may not be your controller.
Jul 05, 2014 | Eagle 100 DC 1/2HP Swing Gate Operator w /...
Pins location master slave
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
Hope this helps
Nov 24, 2012 | Gateway Motherboard Gt5408 Gt5438 Gm5407e...
I need to put my hard drive into an enclosure but I cannot figure out if I need to switch it to a slave before adding it to another computer
i have done this alot for my customers and its really simple. if you look up your drive and get the jumper settings for it and set it to cable select or master in a one drive enclosure it will work well. i do not recommend putting it on slave because some enclosures will not recognize the drive, I do recommend having an enclosure with a fan on board and an external power switch. the reason it the fan will extend the life of the drive and the power switch eill allow you to power it on and off without having to flatten (power hot swap) the drive. Hot swap is ok but this is better than just unplugging the drive. removing the power from the drive keeps the drive in park until you re-power. as long as the drive is "parked" it is les likely to cause read/write sector errors.
If you have any problems let me know and please leave positive feedback for me. Jethro
Feb 01, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I have two 3 way dimmers which control an overhead light. One of the switches being the master and the other the slave. For some reason the (master dimmer) has to be on the on position for the slave dimmer...
I have never heard of master and slave 3 way switches. Both switches have to be 3 way or it will do just what you describe. The white traveler wire has to go from switch to switch, It is a nightmare to figure out sometimes, depending on what is being switched. I have seen electricians walk away from their jobs over 3 way switches. If you get a new switch, the instructions are in the box. Hope this helps.
Jun 30, 2010 | Leviton Decora Light Dimmer Switch
I am getting an error message of setup did not
Hmm did you plug in the cables to the HD right or set it to Slave instead of Master drive ( it's on the back of the HD next to where you plug in all the cables, has a little switch and says "Master" or "Slave" switch to Master )?
Nov 18, 2009 | Compaq Presario 5000 PC Desktop
I purchased the dual brite motion sensing lights and put two of them on my garage, i wired them from a switch to either side of the door on one circuit allowing them to be individual sensors but i keep...
are you using fluorescent bulbs? I had the same problem in my stairway/hallway till I switched to master/slave. Why don't you want master/slave? What's the diff?
I think each switch allows a certain amount of current to pass...with one switch, it's not enough to light the bulb; two switches, you get a faint light.
May 15, 2009 | Heath Zenith SL-6136-WH Basic Solutions...
WD drive won't work as master when Seagate 80GB drive connected as slave.
The jumpers on the Seagate must be set to slave.
otherwise they are conflicting for the Active partion and bootloader.
Regards
Richard.
Apr 26, 2009 | Western Digital Caviar WD200BB 20 GB Hard...
Install dvd drive
Refer to the picture below:
The CD drive should have 3 jumper pins labeled Master (MA), Slave(SL) and Cable Select (CL) at the back near the interface ribbon cable.  In this picture the green jumper is in the Master position.  To make it a Slave drive, you need to remove the jumper and place it in the middle pair called SL.  You may have to remove the CD drive if you can't access it while in the system.  When you put in the new DVD drive ensure that its' jumper is in the Master positon.  The drives will not work if both have jumpers in the same position.
Get back to me if you need more help.
Oct 19, 2007 | Computers & Internet
Installing dvd drive
When you connect two drives to a IDE cable, one of the must be 'master' and one 'slave', whichever is master will show up first and slave will be second.
If you're only using one drive, it needs to be set for 'single', (which may or may not be the same as 'master'.
Look on the back of the drives, near where the cable plugs in, and there'll be some pins with jumpers on them, there may be a C M S (in any order) by the sets of pins, the M and S are for Master and Slave.  The C setting requires a special cable, so we won't worry about it.  There may be something on the drive's label that says what the proper jumper setting is, check there.
Oct 19, 2007 | Systemax AOL Optimized PC (100607) PC...
Failed to load to windows XP
wow yea it's looking for grub/linux i did that same thing once you need the xp install disc insert that hopefully you can get into your bios then go and set it to boot from disc restart and go through the options till you get to repair and type in fixmbr
Oct 06, 2007 | ASUS P4PE Motherboard
Lutron  ELECTRONICS CO. Q-603PH-WH "QUOTO" 3 WAY DIMMER Logo
Top Lutron Electrical Supplies Experts
Steve
jdthefixer
ken skalski
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
