Question about Norelco T960 Beard Trimmer
How do i replace a battery on a norelco t960 beard trimmer?
5 Suggested Answers
SOURCE: Battery Replacement for Remington PG-300 Beard Trimmer
Hi
The manual will give you info on the battery that is inside the trimmer.If you can get to the battery then buy same TYPE or similar to the original---VOLTAGE/CURRENT RATING/CHARGING etc and size, connection
Hope this helps
Jay
Posted on Nov 17, 2007
SOURCE: conair beard trimmer: took screw out and can't
After removing the screw you must place your thumb on the battery cover (just below the screw where the 5 raised lines are) and slide the cover downward. The battery in this unit is soldered in. You may have to take it to a repair center to get the battery changed. The battery is a D-Sc type 1600mAh 1.2V. Good luck finding one. I thought the battery in my trimmer was bad after it sat idle for about 8 years. Turns out a little light sewing machine oil on the cutter head made it spring back to life.
Posted on Jan 15, 2010
SOURCE: How to open case on Norelco T-3000 beard trimmer
Remove the bottom screw. Next, the on/off slide switch has to be lifted off carefully with a small flat screw driver. Its kept in place with a small spring steel clamp. After you've removed it lift off the steel clamp and remove the slide mechanism by carefully twisting it out of position. Once that's done it will twist open easily.
Posted on Dec 24, 2010
  • 3 Answers
SOURCE: how to get out dead
Remove the screw from the bottom. The on/off switch snaps off.
Then gently work a thin bladed screwdriver in the bottom next to
the screw hole. Pry gently - the top (with the charge light and
the name written on it) slides downward about 3/16 of an inch
and lifts off. Unsolder the old battery from the board and solder
the new one in. Then snap it back together and put the screw
back in. The switch takes a little patience, but it'll snap back on.
Posted on Feb 02, 2011
Back put together trimmer
I've written up a complete step-by-step tutorial on how to replace the battery on a Remington MB-300 Beard trimmer, which includes how to reassemble it: John Fixes Stuff How to Replace the Batteries in Remington MB 300 Beard...
Dec 09, 2013 | Remington MB-300 Beard Trimmer
How do i open my norelco g380 to change the battery
If you use a small flat blade screwdriver you can gently pry it apart, there is no glue holding it together. I replaced my battery recently. It utilizes a AA NiMh battery with tabs on it. See pictures for more details.
Dec 23, 2012 | Philips G380 Beard Trimmer
How do I replace the battery on my Norelco D-finer D350?
try checking on placement of the batteries where it is screwed outside. you unscrew it and open the cover then change the batteries.. you can also sneak into the manual for sure..
Apr 28, 2011 | Norelco D-Finer D350 Beard Trimmer
Jul 25, 2009 | Norelco Health & Beauty
How do I change the Battery in My Norelco T3000 Beard Trimer
Remove Phillips head screw at bottom of trimmer. Separate body in two being careful to notice how on/off switch is assembled. Unsolder the ni-cad battery from circuit board. Install new ni-cad battery of the same physical size that has solder tabs on it and solder it to the circuit board. I used a ni-hi (nickle metel hydride) instead of ni-cad which had different charging requirements so I limit charge time to no more than 16 hours for a discharged battery. It had been working fine for over a year. Don't forget to apply a few drops of light oil to the cutting blades to extend cutting life. Replacement blades are about $30.00
Jul 06, 2009 | Norelco T770 Beard Trimmer
DOES NOT CHARGE
If you still have it I have one I dropped. The body is still fine, and the batteries charge. A piece broke off inside the cutting blades. Let me know if I can help. Thank You, Jeff
Jan 15, 2009 | Norelco G270 Beard Trimmer
Norelco T960 Beard Trimmer Logo
200 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
