Washer won't work
Show F and DL
    President:
  • 1,776 Answers
This code indicates a "door lock" error. The door lock switch may be faulty. It can be tested using a multimeter or ohmmeter. A lack of continuity indicates a bad switch. Make sure the electrical connections are clean and tight at the switch. Check out the video at the link I'm
It may assist you in the project. I sure hope so and I'm sorry for your trouble. Best wishes and hope this helped.
http://www.youtube.com/watch?v=fC8SY3cU1Yc&feature=PlayList&p=A8EAB62928245279&playnext=1&playnext_from=PL&index=61
Posted on Sep 07, 2009
What wrong with my washer when it says DL
your washer has problem with door switch replace it.it will work fine.
Feb 15, 2013 | LG WT5001CW Washer
Door won't lock, displays F DL
hold them responcible, they need to correct this for you. you spent good money make them correct the problem
Jan 07, 2012 | Whirlpool duet Washing Machines
The DL error just came on. Is there something specific we need to do to fix this? It has been working fine, but then all the sudden the error started. Upon initial machine start, it works fine, but then if...
Presumably it is still under guarantee/warantee? You should contact the washer's service department before doing anything else as 'DL' does stand for Door Lock (error).
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor needing an engineer's attention ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 16, 2011 | LG WM2277H Front Load Washer
Washer is not working
this code is for a door lock failure. it can also be a ccu problem as well. some have had luck hitting the back right corner of the machine forcefully to remedy this problem.
Jul 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer show code dL
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!
Apr 14, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Start and after few minutes show "dl" f
easy fix, door lock failure, replace door lock asm. on old duet this part is same as GE, and samsung parts. new duets differ
Apr 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My screen in showing code "dl" and then "f", please help?
The "dl" code is "doorlock" indicating a problem with the door locking mechanism or switch
Apr 19, 2009 | Kenmore Elite HE4 Electric Dryer
Washing machine
Do you mean "F dl"? That's a problem with the door lock - it tries to lock the door but for some reason (usually mechanical) it can't. Try closing it a little firmer. Sometimes the mechanism needs an extra push to get it to throw from one mode to another. If that doesn't help replace the latch mechanism. if that doesn't work replace the CCU assembly.
Jan 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
