KitchenAid KAWS850L Top Load Washer
Problem for KitchenAid KAWS850L Top Load Washer
KitchenAid Stylemaster 622784 cleaning the fabric
By kthymllr on Sep 07, 2009
KitchenAid Stylemaster 622784 cleaning the fabric softener dispenser. I can't get the fabric softener apart to clean it. I don't have a manual. I bought it, used, with no manual. Suggestions?
Comments:
Sep 07, 2009
- I can't get the dispenser off. I've tried pulling it off, but it won't come off. It will turn fairly easily, but not come off. Suggestions?
Best Solution
posted on Sep 07, 2009
Very Helpful)
rylee_smith
Rank: Guru
Rating: 88%, 1050 votes
Hi
Thanks for using FixYa. Remove the dispenser and spray with white vinegar. Then spray the agitator with it too. You can pretty much wipe it right out. Vinegar dissolves softener very quickly. The dispenser just wash out with warm water after the vinegar sits on it for a minute, and you hardly have to wipe at it at all. try adding bleach to the dispenser and clean it with a small brush.
The dispenser will pull off from the agitator and you can run hot water in it from the sink. The agitator is not as easy but has a 1/2" bolt holding it to the shaft. remove the bolt and pull up. but you can clean the whole washer with a cup of bleach and that will also clean the agitator. Now run a full tub of hot water and then add a cup of bleach with no soap. After the washer has filled up, then add another gallon of hot water and that will help to rinse out the residues that cause odors. then after that dont use too much soap and you wont have residue build up. Only use the smallest amount of soap that the cup has marked in it.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Comments:
Sep 07, 2009
- Hi
You can remove it by snapping out the nubs, there are about half a dozen nubs spaced evenly around the bottom of the dispenser which snap into a lip around the inside of the agitator's top. Use a plier if you want to.
You can remove it by holding the agitator steady with one hand and firmly pulling upwards on & the dispenser snaps out. Replacing the dispenser is simply a matter of snapping it back into place.
Thanks
Rylee
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thanks for the help! However, I can't seem to get the dispenser off. It rotates freely, but won't pull off. Suggestions? " - kthymllr
Popular Solutions for KitchenAid KAWS850L Top Load
Questions and Unsolved Problems for KitchenAid KAWS850L Top Load
Do you recommend KitchenAid KAWS850L Top Load Washer?
Answer
Answer
how do i remove agitator from a moffat mnxr1070, there does not appear to be a bolt under softener... (More)
Answer
I have a washer tub that seems to be off balance with no load.
Answer
the washer leaks and the spin cycle isn't spinning right, they come out still very wet. Please help... (More)
Answer
When I put the washer on wash or rinse the agitator/washer works but when I put the dial on spin... (More)
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in Newport, KY
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
