Question about Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum
How much water goes in the vaccuum
I have never used a steam vac and i cannot find the instruction manual and can't figure out how to work it.
  • 268 Answers
I have a simular model. Here's what I do.
On the fill tank (that's the top tank), look on the front and you'll see where it says "Fill Line". Fill this with hot water first (so it doesn't foam up) and then add your cleaning solution. Make sure the lid on the bottom tank is on tight. It should snap in place. Top should also snap into place. Turn on and pull trigger and move forward a few feet, let go of trigger and solution will stop coming out. Do this a few times and then without pulling trigger, go over the same area you just did to pick up water. Repeat this until you are done. When the bottom tank is full, it will sound a little loader and higher pitch. Just empty tank and put back in and continue.
Hope this helps.
Posted on Sep 17, 2009
Not Steaming
this link is for the manual it will give you full instructions why it wont steam
http://www.sharkclean.com/manual/MV2010_11_IB_ENG_110103.pdf
Apr 15, 2013 | Shark 2-in-1 Vac Then Steam Bagless Vacuum...
How do you connect the stair and upholstery hose to the hoover steam vac
You can download your manual at Hoover.com under Service and Support - Download Manuals. It's acutally very easy to connect: With cleaner unplugged, open the hose connection port on the top of the suction nozzle (much easier to just follow the pictures than to figure out from my description) and plug in the short hose end. Plug the solution tube into its connection port on the side of the lower unit (in front of the wheel). You'll also want to check out the instructions for cleanup.
Oct 04, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hover steam vac Model #F5897-900
When I use my Hover Steam Vac, it smells like rubber is burning. How do I fix this?
Jun 16, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Lost Manual for Hoover Steam Vac Model #5906-900
Visit www.hoover.co.uk
There you can pick after sales service,instruction manuals, etc. etc.
You will find your manual there.
I hope this helps
May 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Spin brush removal
Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
follows:
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
Oct 19, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac spin scrub
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40488&thid=640907
Posted by mid-nite on Jun 02, 2008
My aunt lost the instructions to her steam vac, and she never got the chance to read them. Do you know how to operate it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac F5914-900 Spin Scrub Upright. The best thing to get an owners manual is to download the owner’s manual from the Hoover website or to call your local vac dealer or to call the Hoover Factory / Manufacturer to have them send you out in the mail a new owner’s manual for the model you have listed above . the phone 3 are listed below:
. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 02, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Trying to find instructions
I have that cleaner also (bought used for $10) and do not have a manual. I found a manual for F5914-900 at the Hoover site that seems to be similar. Get it at
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Jan 03, 2008 | Hoover F5835900 Upright Steam Vacuum
Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum Logo
118 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
