Question about Northstar Garden
Oil leak at top of pump
I have a bored North Star pressure washer with a Honda GC 190 motor and a Comet GXD 2627 pump. It appears that oil is leak out around the cap with the yellow top at the top of the pump. Do I need to add oil? If so how much and what type? How do I stop the leak?
Thanks for a quick reply.
  • mactarheel Sep 07, 2009
    That should have read "I have a borrowed North Star..." not "bored".
    New Friend:
I have a follow up question: where is the drain plug on this pump? I can't find one at all.
Thanks
Posted on Sep 04, 2016
  • 174 Answers
The oil in the pump is probably leaking because a seal is blown and water is getting into the piston housing. Take a look inside at the oil. It should be brown and translucent. If it is gray, white or milky, you have a blown oil seal. This reservoir should only be 1/3 full of non-detergent oil to begin with. Hope this helps
Posted on Sep 10, 2009
Why is the oil in my honda gc 190 grey
grey oil is water contamination. check for leaking seals to stop water getting to the oil
May 21, 2015 | Karcher 3000 PSI Gas Pressure Washer with...
Needs oil change ; what is correct oil to use ?
Typically they use a 10w30 oil in the engine and a non-detergent SAE30 oil in the pump portion.
May 06, 2014 | Honda Garden
I have a North Star pressure washer GC160. What oil do I use in pump and what is recomended for the Honda engine? Can you also tell me where I can download a manual? Bob
As far as the pump gose just use a 30 weight oil they call it pump oil but realy its a 30 weight oil if you want the # its AW-4085-0016 or equivlant . The engine oil is a 10 -30 in most tempatures they say use a 30 wight above 40 degrees but i use mobil one extend proformance 10 -30 all year long in all of my mechines and have never had any problems and there all honda engines . Just change the oil every year some of mind are 35 years oil and run perfictly
May 09, 2011 | Northstar Pressure Washer 2800 PSI
I have water in the oil in the comet pump/ZWD 4030. It is on a North Star 3000 hpw.
You have a seal failure, you need to reseal the pump and change the oil in the pump.
Nov 04, 2010 | Northstar Garden
I have a Comet 4040 and oil and water mix is bubbling out of the red cap on top of my pressure washer. Can anyone tell me what repair kit I might need to fix this problem?
Hi this could be the oil and pump seals worn. Also make sure that you don,t have the transit plug in or the pump cannot breath. It should have a air vented dipstick.
May 21, 2010 | Comet GXD2527G Pressure Washer Pump
Oil grade and level in pump reservoir? Motor is shutting down, all else seems fine, assume is oil level. North Star with Honda GX340 - pressure washer.
15-40 there will be a fill mark that is easy to see when you remove the cap or it will have a dip stick
Second your oil pressure switch may be bad or have a bad connection
Mar 06, 2010 | Hardware & Accessories
I tried to start my honda gc 190 and noted the air
Worn rings or valves and valve will do it.
Also over filling the crankcase with oil which is most likely because it is a common error. Especially if it is not a high mileage bike.
Hope this helps!
Rob
Sep 27, 2009 | Garden
Oil for Comet pump
aftermarket oil will be fine just use same grade of oil,all manufacturers want that extra kick,
May 12, 2009 | Comet GXD2527G Pressure Washer Pump
I have a MTPAXR 8/120 PUMP THAT IS seized and I
The best tool for this job is a gearpuller -- there are many types -- get one which matches your problem.
May 08, 2009 | Comet BXD2527 Pressure Washer Pump
Garden Logo
830 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
