Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Will not pump out water after rinse cysle - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
  • 867 Answers
If water pumps out fine after wash cycle, this means it a control panel issue, may need to be replaced
Posted on Sep 10, 2009
Causes of low rinse water pressure on a Hobart ft900-d washer
For a machine without a break-tank (a.k.a. cistern) and booster pump: check the inline debris strainer on the rinse water pipework; check you're not missing any rinse jets; check the inlet valve is fully opening.
For a boosted machine, check the pump impeller isn't disintegrating; check that the flexible hoses to the booster pump aren't collapsing internally.
For both machines: descale if you're in a hard water area.
Mar 15, 2015 | Hobart Dishwashers
I have Hobard LXIH dishwasher, it is working OK but during rinse cycle instead of taking in rinse agent it is actually fill rinse bottle back with water. Rinse pump is working, it was replaced in June
Check the rinse pump. The tubing needs to come from the supply into the bottom of the pump, and the pump should be running clockwise. If the pump tube is worn, the rinse pressure will blow through the pump filling the bottle
Dec 12, 2013 | Hobart Dishwashers
Washer doesn't complete spin cycle, it stops with a barrel full of water. It doesn't matter if it's set on extra rinse or not.
The wheel on the botton has a plastic white insert that will lift or retract the gear stem. Depending on the ratation of the motor this will pull or retact that stem. During spin cysle, the wheel rotates CCW and pulls that stem out(towards the floor). This action should disengage the brake and also start rotating the tum. Remove power, remove the belt and rotate wheel manually and see if the empty tub spins. If not, remove the wheel and take care to not drop all the washers and bearings. Once removed take some vice grips and yank on that gear stem until the brake mechanisn is released. That stem should only need to move a few mm maybe 5-10. Once fully reassembled if this continues to happen, get a new pully assembly.
Sep 23, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Water pump evacuates water but does not pump in the wash or rinse
You assume correct. The control board switches the direction, but if there's a mechanical problem like a bad start capacitor, then it won't run
Jul 29, 2017 | Kelvinator MDB121RF Dishwasher
During short spin cycles between rinses it doesn't pump water out
Try looking to see if the little motor is spinning the drain pump. It is in the bottom right. Occasionally I get a small metal shard which locks the pump and therefore-no draining. You can undo everything and check the pump for blockage. Then if need be, replace the mechanisim. The parts are all on line, as is the manual. or call 800 776-3538
May 11, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Very noisy
You may have something lodged in the pump that is causing it to rattle a bit.. Depending on the model, you may need to remove or disable power, then gain access to the pump by removing the toekick panel from the front.. You may also be able to zero in on the specific cause of that rattle by removing that toekick and cysling the dishwasher while listening for the source of that rattle.. A flashlight may help spot that source.. Hope that at least gets you headed in the right direction... Re-post if you still have an issue..
Regards,
Rick
Feb 16, 2009 | Kenmore Dishwashers
The washer stops before the rinse cysle
That sounds like your lid switch. This switch is located on the top. Raise the lid, Looking down at the washing machine it is the little hole. If you push it down with your finger on mine it's grey in color. The problem is that the switch is not getting pushed down far enough. if you pull it down manually with your hand a little farther you should hear it click over and the machine might scare you as it starts up into the rinse cycle. You can purchase them pretty cheap online at any applince site.
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
No water going in to dishwasher when rinsing
the pump shouldn't turn on when the rinse cycle is on - it uses only fresh water straight from the water line - after the wash cycle is over - wait 5 seconds, then open the doors and see if there is any rinse coming out of the rinse arms.
If only a little is coming out - check the rinse arm spray jets to see if there is debris caught in them -
if no water is coming out - it could be a faulty rinse solenoid
Aug 05, 2008 | Hobart AM14-253 Free-standing Dishwasher
Hobart lx30 : rinse cycle
The rinse water in a LX30 is driven by water pressure. A solenoid valve, bottom front - gold body, opens up and allows the water to flow.
If you are referring to the rinse agent pump, there must be NO leaks in the tubing or the hose that runs through the pump. And if the unit has lost its prime, using your hand to "seal" it, and forcing water from the faucet into the line can prime it.
Good luck - Mike
May 13, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
69 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
