I would like to be able to change my label orientation. I print from SAP bar code labels, but i need to rotate it 90ยบ.
The problem is that the driver not have the rotate option,
SOURCE: print orientation
If you are printing from the included software, it has options for labels with vertical printing. If printing from a third party program, you can go to the dirver settings and change the printing orientation.
SOURCE: Sizing and Orientation problem on Zebra 140 Xill
Check the size of report-page and if it is in inches or cm.
SOURCE: Zebra TLP 2824 Print Orientation
check on the driver, unther the advance tab, if some seting is tick.
if cant check the problem, install the driver again.
SOURCE: can't get labels to print with correct
It could be a driver issue but check the following also:
Most printers have a "setup" or test page\orientation mode.
If available, check that first.
Also, most labeling applications also have a "setup" script which you need to run to align the output.
Check your application for such a tool.
