WANT TO ATTACH GRASS TRIMER
Look at the top of the head (where the brush cutter is) find the small hole about 3/16 diameter. Insert an allen wrench or a large nail, or anything else that will fit in the hole almost the same size as the hole. While putting a little downward pressure on this "tool" turn you blade slowly by hand until you feel the tool slide into the locking slot, this will hold the blade from turning. Keeping it in this position, take a socket and ratchet on the nut that is holding the blade and loosen and remove it. THE NUT HAS LEFT HAND THREADS SO TURN IT OPPOSITE OF WHAT YOU NORMALLY WOULD TO REMOVE IT!!!!
