My washing machine will not spin and smells like something is burnng.
  • Washing Mach... Master
  • 2,005 Answers
Your spin clutch works like a brake and, it has shoes like a brake on your car.
you need to replace the spin clutch
Posted on Sep 07, 2009
  • 60 Answers
I think that your washing machines motor is shot. probably has an ozone smell to it. you can keep using it with smaller loads.
    Sergeant:
    Champion:
  • 255 Answers
Check belt going to motor or motor is bad
Burning smell
There's a number of reasons to smell burning after a washing machine cycle. It's a 220V appliance, so if it short's out it will cause problems. It's more likely the motor being overloaded making it hot and causing the electrical burning smell, or a short that's overheating something electrical. Check to see if the belt that spins the whole barrel is melted or worn anywhere. Inspect the wiring that's attached to the system that engages spin, which is different from agitation by the big tower.
If these both check out, an trip to the Maytag Man might have to fix overloading motors or relays, or switches, if anything turns up in your search for the source of the electrical smoke. Ozone is what you are smelling, FYI.
May 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
My washing machine will not drain,
2or 3 possibilitiies .faulty lid switch...if machine spins,lid switch is ok.something caught in water pump (very common),or a bad motor,(no spin or agitation),accompanied by burning smell usually..pls note:if something in pump,this can also prevent motor movement and cause overheating too
Mar 09, 2010 | Kenmore Washing Machines
Washed something too heavy, now washer does not spin or agitate, has burning smell
Burning smell is the precursor of fire. If you do not understand what that means.....Get a Techo out immediately and NEVER use the machine again until it is repaired properly. !
Oct 25, 2009 | Washing Machines
GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
Jul 07, 2009 | Washing Machines
My Kenmore washing machine had a faint burning smell.
i would let it sit for an hour. more than likley what happened was the motor overheated a little because it was trying to spin in an off balance situation. give it a break for a while the next load that you do keep an eye on it and see if you smell anything if you do then you have a problem. But 99% it is ok.
Jun 28, 2009 | Washing Machines
Won't spin on spin cycle, smells of something burning.
sounds like the belt or the tub bearings are shot. It is likely that the motor is spinning and the tub is not, causing the belt to burn.
May 25, 2009 | Maytag Washing Machines
Washing Machine Problem
if this is a sears or roper or whirlpool unit then check the direct drive coupling, if it sound like it should be spinning but doesn't
May 17, 2008 | Washing Machines
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
