Question about Zenith ZHX-313 System
Progressive scan mode will not disable
I accidentally activated the progressive scan feature on my zenith sorround sound dvd/vhs player zenith m# zhx313. Now I can not clear the Progressive Scan feature and I can't watch any of my movies. Help!
  • 3 more comments
  • janbella07 Apr 11, 2008
    i have the same problem but I also lost my manual so therefore I can't do nothing
  • me rev May 06, 2008
    progressive scan won't turn off
  • Anonymous Nov 08, 2008
  • Anonymous Nov 30, 2008
    I activated mp progressive scan and don't know how to shut it off
  • Anonymous Dec 04, 2008
    Can this solution work for a Philips DVD QAT?
Hi, you must hold 1st remove the disc (if you have one in) then hold down the STOP which is just under the RECORD button. Hold it for about 6 to 8 seconds. That should clear it.
Good luck
trestaris
Posted on Dec 15, 2007
  • joeen bright May 10, 2013
    this did not resolve my issue...it still is showing...progressive scan.
If you remove the disk of there is one in then hold down on the stop button for 4-6 seconds it should clear it all
Posted on Aug 04, 2008
OMG! thank u so much. it worked and everythings back normal again!!!!!!!!!!!!!!! Excellent!!
Posted on Jul 25, 2008
Thank you very much!
This helped me too. I got this DVD player for $10 but have an older TV. I don't have a remote so I was in the dark.
Posted on Dec 16, 2007
I do not have the remote for my Memorex DVD player and it is stuck on the Progressive scan. I would like to know what can be done to remove it from my TV screen,
Posted on Apr 21, 2008
I was playing with settings on my Zenith xbv342 and set the menu to progressive scan. I now have a blue screen with the words "progressive scan mode" I cannot get a picture and it is stuck in this m
Progressive scan mode is used by DVD players to artificially scale standard resolution DVDs to HD resolution, usually 720i. Is your set capable of receiving HD resolution? If not, that is probably why you are getting the blue screen.
Dec 18, 2014 | Zenith XBV342 DVD Player/VCR
NO VIDEO BUT HAVE SOUND
Good day! Try to check the rca jack video input.Replace it with new one if defective. Also check the progressive scan features if activated. If it is activated check your TV if supported by progressive scan features, because some TV is not supported by progressive scan.You can deactivate it by turning off or activate the interlace mode.Press the open/close to open disk tray. And press the numeric keypad 1 for few seconds. Hope its help.
Sep 07, 2011 | Philips DVP-3005 DVD Player
How do I get back to the Meue that I will show progressive scan mode. to remove progressive scan mode, because its stuck on the DVD, whereas we can't see the movie but we can hear the sound. I tried to...
1) Remove any DVD that may be inside
2) Press AND Hold Stop Button (on front of Player) for 5 or more seconds
3) All Done - This will have reset player back to Interlaced Mode and you can now see your DVD!
Feb 15, 2011 | Zenith XBV343 DVD Player/VCR
I have a HD TV with cable and a go video DVD/VHS player hooked up. I went to change the time and accidentally changed the setting on the DVD player from auto scan (I think) from off to on and now when I...
It sounds like you may have enabled the progressive scan output on your DVD-VHS combo. This is a correct setting if your TV support it. However most DVD players that support progressive scan will not support an interlaced signal and a progressive signal at the same time.
It would appear that you are using a composite type cable (3 RCA ends. 1 for video and 2 for audio) for this hook up. This means you have two choices.
#1 Look in the manual for the unit for the FACTORY Reset option. Its usually a combination of plugging the unit in while holding the power button or something similar to that. Without a model # I can't help any further with this option.
#2 Use a component video cable (3 RCA red/green/blue) to plug your DVD/VHS player into a compatible input on your HD TV. Your TV will pick up the progressive scan output from the unit and give you back your on screen display. At this point you can go back into the menu and disable progressive scan. And now just reverse the process to plug the DVD player back in using the composite cable.
It should be noted that if you have a progressive scan TV which HD TV's support you will get a better picture if you use the Component video cables instead of switching back to the composite cable. If you decide to use the component cables you will still need to run audio cables though.
Best of luck.
Trevor
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Progressive scan mode on screen
Your television probally does not support progressive scan mod. many do not.
Apr 12, 2009 | Zenith XBV342 DVD Player/VCR
Stuck with progressive scan mode
My dear friend try with this,turn on the dvd take out the disc open the tray now push for 5 seconds the button stop.Good luck.
Jun 18, 2008 | Zenith XBV243 DVD Player/VCR
DVD Player Stuck In Progressive Scan Mode
A simple solution that works with electronic items many times, so give it a try. Turn Off your player, un-plug the electrical supply, wait about 2 minutes then re-connect the electricity and turn on the player. Many times this will force the machine to reset itself. This technique can be used for ALL electroinc devices.
Jan 16, 2008 | Zenith XBV243 DVD Player/VCR
Progressive scan
I have a zenith dvd/vcr receiver model LH-C245M i accidentally put it on progressive scan mode and appears on on my TV screen how can i get back to normal viewing? can you help me with this one Please. Thank you hoping for your great response.
Jan 11, 2008 | Progressive DVHE210 210 DVD Player
No picture but has sound
Hi If your t.v.has built-in blue screen when there is no signal, then the DVD may have been accidentally switched to progressive scan mode, or defaults to that setting if new. If your T.V. is not capable of displaying in progressive scan mode, you will just get a blue screen. If you have an older tv, without blue screen, then connect it to that, and if you get a black and white split screen when you turn on the DVD, then progressive scan is the problem. Check the manual for the DVD player for the procedure to get out of that mode, and it should then work. If you still have no video, and you are using the yellow composite video jack on the back of your DVD player, then it must be brought in for service. Good Luck!
Aug 14, 2006 | Zenith DVB312 DVD Player
Zenith ZHX-313 System Logo
655 people viewed this question
Top Zenith Audio Players & Recorders Experts
Marvin
Marvin
xalint1
xalint1
Gagan Telecom
Gagan Telecom
Level 1 Expert
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
