Question about Kohler Home
Tank wont refill after flushing. - Kohler Home
  • 396 Answers
The ball **** controls the water flow into the tank when flushed. If the float is stuck in the up position, the water will not fill the tank or the valve could be defective. If after pushing down the float and observing little or no water you need to replace the ball **** or the water valve is turned off. Turn the water off at the shutoff valve. Put a towel under the water supply hose and unscrew the water supply hose at the bottom of the ball ****. Drain any excess water at the bottom of the tank using a shop towel or paper towels ringing them out when they become saturated with water. Remove the ball **** and replace the old one with a new one available from a hardware store. Make sure to follow instructions on washer placement to avoid leaks. Replace the water supply hose and tighten snugly and be careful not to over tighten to crack any plastic. Turn on the water shutoff valve and adjust the float so the water stops at the tank water line.
Posted on Sep 08, 2009
4 Suggested Answers
  • 14 Answers
SOURCE: Toto Toilet - no water flow to refill tank after flush
Remove the tank lid and look at the fill valve. Is it a yellow valve?
This fill valve is common on the Toto Toilets and can easliy plug with debrie.
They can be disassmbled and cleaned. however, I usually just replace the valve with Fluid Master Fill valve.
You will also want to check the water coming into the toilet by turning off the water that supplies the toilet and disconnecting the water supply line. After removing the water supply line turn on the water at the valve to make sure that the water is flowing properly. Check the supply line also to make sure it is not plugged.
Be sure and place a small container to catch the water that will come from the valve. A towell will also help from making too much of a mess.
If the Supply line and the valve are clear the problem is in the fill valve.
The G-Max system denotes the Flushiing system which is a 3" flapper that allows the water from the tank to flow into the bowl quicker.
Good Toilets!
sanray
Posted on Jan 10, 2009
SOURCE: tank will not refill after you flush
the toliet tank won't refill after flushing. it has been freezing outside could the water pipe to the tank be frozen if so how could i fix this problem
Posted on Jan 16, 2009
SOURCE: toilet tank will not refill with water after flushing
I fixed the problem. There was a clog in the pipes so i just flushe dthe pipes out.
thanks,
for your help
Posted on Jan 18, 2009
Im a woman so i dont know much about this stuff but my toilet bowl wont refill and i need to know what to do... i have a fluidmaster 200a
Take off the cover and look at the mechanism when you flush. It's possible the set screw that keeps the flush rod in place has just loosened. If not then the easiest way to deal with this is to replace the Toilet Refill Valve. Turn the water line at the base of the toilet to off. Flush until most of the water is out of the tank, the go to Home Depot and buy this:
Fluidmaster Toilet Tank Fill Valve 200AX The Home Depot
Unscrew the old one and screw in the new one.
May 03, 2015 | Home
Tip
How to adjust a toilet
  • Your toilet tank may simply need a good "tune-up." Here are some adjustments you can make.
  • Refill valve. If your tank has a conventional ballcock refill valve, the water level is adjusted by bending the float arm. The level should be high enough for complete flushes, but the water should not be to the top of the overflow pipe. Your tank should have a colored or molded water level mark. It should never be set so low that the bowl does not refill with trap sealing water. The rule of thumb is to set the water level about 3/4" below the top of the overflow pipe.
  • If the float rubs on other parts, simply adjust the float arm sideways. If the float lacks buoyancy, unscrew then shake it to determine if it is waterlogged. A waterlogged float should be replaced. The float arm can also be replaced, if needed.
  • In tanks using modern plastic refill valves, the tank water level is adjusted in other ways. If your tank uses a hand nut, turn the nut clockwise to raise, or counterclockwise to lower, the water level. Or, your tank may have a sliding pinch clamp on an adjustment rod.
  • Flush valve. Replacements for a flush ball and its actuating mechanism are available, but it may be possible to stop a leak with minor adjustments. Check the following mechanisms before purchasing replacements.
  • See that the guide arm is centered directly over the seat. The guide arm should drop the flush ball directly into its seat. If the flush ball is not seating properly, make the adjustment shown.
  • The guide arm should allow the flush ball to rise enough for a complete flush. If not, raise the arm. Be careful that it isn't too high–then it will prevent the ball from closing completely.
  • Check that the upper lift wire pulls the flush ball high enough. To adjust it, simply bend the wire for a higher or lower lift.
  • The lifting hardware on a flapper-type flush valve should raise the rubber flapper to start a flush, but should not hold the flapper up off its seat. If this is occurring, the hardware is adjusted too short. Some types allow you to slide the flapper itself up or down on the refill tube to ensure that the flapper meets the valve seat squarely. The lifting hardware and flapper height adjustments are the first things to check when flapper problems arise.
  • Refill tube. If the bowl-refill tube is out of place, water is routed directly into the tank, rather than replenishing water in the bowl. When this is the case, you will likely hear splashing sounds during tank refill. The refill tube should aim directly into the overflow pipe but should not reach below water level. If the tube extends too low, it will siphon tank water silently away. Fix it by repositioning as shown.
  • Defective refill tubes on some valves can be replaced with new plastic ones. Simply place one end of the plastic tube over the serrated plastic lug on the body of the valve, and place the plastic holder in the top of the overflow pipe.
  • on Jan 16, 2010 | Plumbing
    Why wont my have a cimarron k3489 toilet fully flush? the water empties from the tank but the water from the bowl does not go down.
    That's an interesting one! Does the flush valve close properly so the tank can refill? Does the float valve allow the tank to refill fully, to near the top of the overflow? That can be adjusted, if it doesn't.
    Check fhe flush valve - you may have an obstruction under it. Also check the water port from the bowl side - feel up inside the port for obstructions or buildup of hard water deposits.
    WASH YOUR HANDS THOROUGHLY afterwards.
    Jul 29, 2014 | Kohler K-3489 Cimarron Comfort Height...
    My toilet wont flush just keeps running
    The flapper valve may have deteriorated with age. If it doesn't seat after the toilet is flushed, the tank won't refill and water will continue to flow.
    Jan 20, 2013 | Fluidmaster Plumbing
    We have installed an american standard duel flush toilet that uses a fluidmaster valve. Problem! The refill tube is mounted on a float attached to the overflow pipe. When the toilet is flushed the nozzle...
    The overflow pipe should be attached to a small clip that holds it in position over the over flow pipe. If it is loose or attached to the outside it will do what yours is doing.
    Apr 28, 2017 | American Standard 2480.516 FloWise Dual...
    G-max flushing system is not filling to proper level
    Is it not refilling the tank or the bowl? I've got a toto also that is not fully refilling the bowl after each flush. No leaks or other problems. Tank refills fine. Seems that the flapper doesn't float long enough to allow a sufficient amount of water to drain into the bowl before closing. Any ideas?
    Jan 06, 2010 | Toto Drake ADA Compliant Toilet with...
    Toto toilet: refill valve opens and closes rapidly
    I believe you have a high water pressure going to the
    tank. Minimize the water volume going to your tank. This is done by fully closing the inlet valve under the tank. Then open about 1/4 to 1/3 of the inlet valve. To do this, count the number of turns to get it full close from full open position. For 1/4, divide the number of turns by 4 and divide it by 3, for 1/3 open. Hope this will solve your problem.
    Nov 26, 2009 | Water Heaters
    My dual flush toilet fills up slowly how do i fix
    Lift the tank lid off, place it somewhere safe for a moment, and look at what happens: If you're talking about jiggling the handle to get the tank to start to fill with water, then it sounds like the chain or rope is out of adjustment. It can't be TOO TIGHT or the water will leak past your flapper (will cause your dripping noise, tank water level will leak down, causing constant refills), and it cant be TOO LOOSE or the toilet won't flush correctly. Since you didn't mention trouble flushing the toilet, I think that it may be a little too TIGHT. When you jiggle the flush lever-it is supposed to pull a chain or cable to open the flapper at the bottom of the tank. Flush the tank and watch what happens-all the way through to refilling the tank with water and shutting off the water refill valve-Does the flapper get stuck on the chain or something? It is supposed to fall back down to allow the tank to refill after flushing out your toilet. Does the chain look very loose? The dripping sound you described indicates that the flapper is not sealing 100%. The flapper is very easy to replace, you just have to get the adjustment set for when you flush the toilet how sensitive you need it. You amy have to play with it a little bit before you get the adjustment correct.
    Hope this helps!
    Nov 08, 2009 | Home
    Toilet tank will not refill with water after flushing
    thanks,
    for your help
    Jan 17, 2009 | Toto Carlyle 1-piece Elongated Bowl Toilet
    After flushing, water does not refill the tank.
    yeah sounds as though the ball valve or water inlet valve is stuck in the closed position or jammed so when you flush the loo the water doesnt refill.
    Isolate water service remove valve as required clean/replace re instate test & leave working
    Dec 15, 2008 | Toto Carlyle 1-piece Elongated Bowl Toilet
    Home Logo
    329 people viewed this question
    Top Kohler Home Experts
    john h
    Tim Whalen
    Mike
    Are you a Kohler Home Expert? Answer questions, earn points and help others
