Question about LG LSC183VMA Split System Air Conditioner
Error ch 5
I have a lg split system its just shows CH 5 and dosent work. its the plasma style
  • 5 more comments
  • Anonymous Jul 27, 2008
    the ch 05 error occurs on the display of the unit and also the air conditioner unit when turned on does not start up even over 30 minutes and you need to turn it off and then on again to get it to work. also when the air conditioner finally does turn it, it does not stop heating.
  • geffmanda Dec 08, 2008
    i have a similar provlem on a 54000BTU spli LG aircon unit.CH3 is coming on but when i switch off from mains and switch on after a minute,the unit comes on and the error code goes.its running at 80psi pressure.from Zambia,central Africa
  • upnor Mar 02, 2009
    ch5 shows and power light flashes intermitently.have called engineer but no help so far.
  • earl de gorostiza Nov 26, 2012
    I also encountered ch 5 problem on my lg split type airconditioner ( top model - with plasma filter)on its 5th mos (low to moderate use only) and was repaired by lg technicians by replacing the electronic board of the outdoor unit (completed repairs on its 7 mos due to waiting for parts availabitity - 2mos of waiting). But after 2 mos. again same problem, but now it's near out of warranty period.
    if ever the same problem will recur outside it's warranty period is it just for the consumer to shoulder cost of parts and service knowing now that the product has a weak component that is weak and keeps breaking down?
  • Anonymous Mar 25, 2014
    Plasma light blinks six times and power light twice
  • Anonymous Mar 30, 2014
    I am getting error CH 21, aircon is not working then switches it self off
Check all wiring and connections - ch 5 is a communication error between the indoor unit and the outdoor unit......
Posted on Dec 16, 2007
    Problem Solver:
  • 15 Answers
  • norman medalle
    norman medalle Dec 09, 2007
    just open the link www.myrepairmaster.com ,i'm sure you will be disappointed it's the right choice without spending a lot of money on the repair .
What does the code on the screen mean flashes between ch and 05 ?
CH 5 on these units indicates a communications error between the indoor and outdoor units. Generally, it will require a replacement outdoor board assembly to repair it. Lookup LG parts on the internet or ring them for your nearest Agent or parts. 800 243-0000
Oct 15, 2016 | LG Art Cool LA181CNW Split System Air...
Solution of code Error Ch-10 in LG AC
LG canceled inverter AC ch10 error
Jun 03, 2013 | Heating & Cooling
Lg split system ch 46 error? help!!!
Ch-46Outdoor unit suction sensor fault. Disconnect from PCB and measure resistance. 10 kOhm at 10°C and 4 kOhm at 30°C. If OK replace PCB, if not replace sensor
Jan 07, 2011 | LG Art Cool LA181CNW Split System Air...
LG air conditioner 24awn error code message Ch 6 inside fan runs outside unit not working
CH-06 REFERS Indoor unit coil sensor fault. Disconnect from PCB measure resistance. 10 kOhm at 10C and 4 kOhm at 30C. if not replace sensor. THANKS.
Dec 13, 2010 | LG Art Cool LA121HNP Split System Air...
System 3 in-door with system 4 out door inverter. all in door unit show error code CH24 pls help
CH 24-Splits and Multi Splits = High or low pressure trip. Low at 1 bar High at 35 bar check pressures. Multi V = High pressure trip.
Nov 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
What is error code ch o5
CH-05 Communications Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Oct 06, 2010 | LG LSC183VMA Split System Air Conditioner
Lg split system ch 05 error outside fan not working
Solution # 1, Check Condensor Fan Motor Capacitor 4uf or MFD
# 2, Check Motor Windings
# 3, Check Relay OR Defination Contactor
# 4, Check Connection Terminals
hope will help u 2 solve this
GOOD LUCK
Jan 26, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Ch 5 error code
ch5 error code, means that there is a
communication error (serial comunication) between the outdoor and the indoor unit.
Only for LG-airconditioners.
Jan 02, 2009 | LG Art Cool LA121HNP Split System Air...
LG LSC183VMA Split System Air Conditioner Logo
3,827 people viewed this question
Top LG Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Steve F
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
