my tablet pen has been working fine, and today i plugged it in, and my tablet pen doesn't work. like, ill hover it over the tablet (you know, to move it across teh screen) and it starts clicking everything, and highlights things, like im clicking and holding. and then when i try to click, nothing happens? anyone know what wrong?
my mouse works fine, its just teh pen. ive tried unplugging, and restarting the computer, it doesn't work.
btw, i use a Wacom Bamboo Fun tablet, if anyone could help, that would be great.
I'm just gonna pass on a email from Tech Support I recieved.
"It sounds as though your pen has pressure in proximity. This is present when the tip sensor of your pen is stuck down causing the pen to think that it’s clicking before it’s even touching anything. What you may want to try would be to remove the nib from the tip end of the pen, it pulls straight out with a pair or tweezers or your teeth, and leave that out overnight with the pen left on its side. Place the nib back in the morning and if the issue persists then you may have a defective pen tip."
The rest consists of personal info and warranty advice so I'll leave it there.
It did the same thing to me, it just started clicking when i was still hovering over the tablet. I went to the pen tablet properties and changed the tip feel from soft to hard. If it was on the soft side it was just to sensitive.
Mouse and pen will not work for some reason. The buttons work and everything seems fine. There is a...
(More)
Mouse and pen will not work for some reason. The buttons work and everything seems fine. There is a smudge on the tablet like a rub, which I think may be the problem.
The pressure sensitivity on my tablet is not working. I get one straight black line, theres no...
(More)
The pressure sensitivity on my tablet is not working. I get one straight black line, theres no difference between thick brush strokes and thick ones. I have tried to adjust the sensitivity but its still not working...
help! my Intuos4 tablet is not turning on! It will not light up when plugged in...It will not even...
(More)
help! my Intuos4 tablet is not turning on! It will not light up when plugged in...It will not even register on the computer. What is wrong here?
I have a Bamboo tablet on a Windows XP machine. I have it set to Pen and one monitor. For some...
(More)
I have a Bamboo tablet on a Windows XP machine. I have it set to Pen and one monitor. For some reason, it only covers roughly the top left 1/8 of the monitor screen, while using the whole tablet pad. The tablet worked fine when I installed it and the driver, but hasn't since I restarted the machine. I haven't changed anything - just restarted the machine. How can I fix it?
