Question about Jenn-Air JMC7000 Microwave Oven
Fuse blows after about a week of working.
Same problem....I replaced the fuse, microwave worked fine for about 1 week then blew again. Is this a major fix or should I just plan to buy a new microwave to fit the space above the regular oven?
Thanks, Dave
  • 574 Answers
If you have a fuse that keeps blowing you have a short somewhere May or may not be cheaper to buy a new one
Posted on Sep 07, 2009
Why would the Amana AXP22 be kicking fuse?
You have a serious short circuit, I suggest you call for a service technician
May 31, 2018 | Amana Microwave Ovens
I have a GE JKP62G microwave-oven combo. The oven works fine. The microwave blew the 15 amp fuse. When I replaced the fuse, per your earlier directions, and tried to use the microwave, the new fuse blew....
Cause 1
If too much current passes through the microwave circuitry, the line fuse will blow. If the line fuse blows, the microwave won’t start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. If you don’t resolve the underlying issue, the new fuse will blow too
Cause 2
Main Control Board
The main control board might be defective. However, this is rarely the case. Control boards are often misdiagnosed—check all of the more commonly defective parts. If you have determined that all of the other components are working properly,replace the main control board.
Cause 3
Thermal Fuse
The thermal fuse cuts off power to the microwave if the microwave overheats. To determine if the thermal fuse has blown, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. The thermal fuse cannot be reset—if the fuse is blown, it must be replaced.
Since its a electrical isue cal a liscenced professiona to resolve the issue . Your microwave oven isnt at fault . I belive the supplay to it has issue and would have blown anyway.
May 29, 2018 | GE Microwave Ovens
WHAT WILL MAKE MY GE MICROWAVE WES1384SM2SS FUSE KEEP BLOWING I REPLACED IT ONCE AND AS SOON AS I OPEN THE DOOR IT BLEW AGAIN
The fuse is there to protect your home in case something has gone wrong inside your microwave. Since the fuse has blown twice, you can safely assume that there is something wrong inside. It may be fixable, it may not be economic to fix it. Impossible to troubleshoot electronics without the unit and test equipment.
Jun 04, 2015 | GE Microwave Ovens
Panasonic inverter microwave ct579 killing the 10a fuse. Uk.
Check its transformer so that you will know its fuse size
Sep 12, 2014 | Panasonic Microwave Ovens
GE Spacemaker microwave makes groaning sound when start button is pressed for a second or two then blows the internal fuse. After replacing the fuse everything seemed to work, lights, exhaust fan, cl
Could be a lot of things but most probably a shorted high voltage diode assembly. If not that then the magaetron or capactors. Remember be careful there are high voltages even when the oven is unpluged. The capactors are usually charged and must be discharged. If you don't know what yor doing then time to get a qualfied tech.
Good luck
Feb 14, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Glmv169gsb stopped working
You blew the fuse on the control board. Unplug it, remove the cover to expose the guts, and you should see a fuse. Replace it and try again. If it blows again, then you will likely find it cheaper to get a new microwave than have the control board replaced.
Nov 13, 2013 | Frigidaire GLMV169D Microwave Oven
Microwave blows fuses
A short likely in the wiring for the light or at the safety switch embedded on the side where the door closes----be careful as a 20 amp fuse takes something major to take out.
(for it to blow)
This might be best left to a qualified service person.
Dec 22, 2012 | Microwave Ovens
I have a 2011 KitchenAid microwave (khms2040wwh-1) that just died on me. I replaced a fuse, but it blew the second I tried to heat something. How do I trace the short? This oven has not been knocked about...
With the cover off, disconnect the primary of the power transformer. Now, with a good fuse try again. If the fuse blows again check the three microswitches in the latch assembly. If the fuse doesn't blow than the magnetron or diode are shorted.
Nov 26, 2017 | KitchenAid Microwave Ovens
Viking Microwave Model VMOC205SS little over 4
9 amps is approx. correct. Does magnatron make an odd sound when running? If not, you will need to discharge cap then clean terminals with alcahol. Replace diode as well. Should run correctly.If blows again, replace magnatron. Suggest you put a 12 amp fast blow fuse in circuit and nor a 20 fuse.If you dont have a grill or an oven, use a 10 amp fuse.
Sep 17, 2009 | Viking VMOC205SS Microwave Oven
My microwave/convection oven blew a fuse. replaced it and the convection works but when I try to use the microwave it blows the fuse again. what needs to be fixed?
Typically, when the fuse blows in the microwave, the high voltage capacitor fails and becomes shorted.
The door switches are also configured in such a way that if tampered with (in this case, failed switch or latch) the fuse will also blow. Check the capacitor first.
If you need further assistance let me know
Regards,
reg501
The FixYa Team
Jun 19, 2008 | Microwave Ovens
Jenn-Air JMC7000 Microwave Oven Logo
205 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
