Question about Northgate (STAX2517C2) PC Desktop
When i press the power on switck at the front,
When i press the power on switch at the front, nothing happens. I was given the computer and when i looked further at it i noticed that the 115-230 volt switch was on 115. if it was powered up at 115 would it blow the power supply? I don't know please help Thank Gareth
  • gareth_1979 Sep 07, 2009
    The pins next to the cmos battery? there are three with a plastic sleave over two of them, is that them?
    the only pins that i think you mean are set next to the cmos battery. three pins two arched together with a sleave with meatal conductor inside it tried that did not work. i've searched the board throughly and can't find anything with CMOs written on it?
  • 916 Answers
No 115 would not blow the power supply it would just provide less power. Look at the motherboard for pins that say CMOS on them. Move the small plastic piece on top of the CLR pins and then count to 30. Once you have move them back and then test the machine.
Posted on Sep 07, 2009
Testimonial: "Thanks for trying. i just don't know enough and frustrated that i cant't find anything with CMOS written on it Thanks anyway."
  • machadojr_fe Sep 07, 2009
    No not the battery right underneath them it will say cmos you may need a magnifying glass to see the letters. It is usually is a set of 3 or 4 pins.
    I see you gave me a 1 thumbs up or inappropriate rating I'm sorry but I gave you adequate advice and a solution that works for most machines. Since it didn't their are three possible problems that is that either the power button, the power supply, or the motherboard needs to be replaced. The way to test each is with a known good one.
Pc doesn't start up
If nothing happens at all it sounds like a power problem, check the fuse in the mains plug, check for an on/off switch on the back of the computer, if neither of these are your problem then it may be a faulty power supply or simply a faulty switch on the front. Hope this helps.
Mar 03, 2013 | Computers & Internet
OK, following your advice of March 9th I got a new lamp from Mitsubishi and replaced it tonigh in my Mitsubishi rear projection model WD-62725 TV. The old lamp was clearly broken. However I have...
hi,
That sound may from the color wheel. Open the angine, open block front of lamp.
open cover of color wheel and grap it.
mas_baz_23.jpg Rotate color wheel manualy , listen it. If hear fristing sound, means color wheel is bad. Replace it too.
mas_baz_24.jpg Good luck.
Mar 24, 2011 | Televison & Video
Dishwasher won't start. The Quick Rinse light is blinking on the front panel. I pressed every button but nothing happens.
The light blinking indicates that the program is ready to start but has not received the go signal from the Start / Stop b utton as the switch is probably faulty.
Try to reset the machine by disconnecting the mains power, waiting at least 10 seconds and then reconnecting. Try to start the machine in the normal way and if it still will not start then it means that the switck control is faulty or the control unit has a fault.
Yo will probably have to call a dishwasher technician to rectify the problem.
Jan 10, 2011 | Kenmore 13599 / 13594 / 13592 Built-in...
We have a 2006 Honda Odyssey. All of a sudden the front passenger and both rear windows will not open. We have the safety button on the "unlock" position but when you press the button to unlock those three...
this sounds to me like the switck that locks the windows is stuck. replace it. or of you have the know how take the switch apart and you should see the issue. but you may not be able to repair it. i have repair these kind of switchs before but you can fix them this way all the time
Jul 29, 2010 | 2006 Honda Odyssey
My ga-ma785gm-us2h won't turn on, no power or nothing. I hit the power switch on the front of the case but nothing happens no fans spin or anything.
check the power supply is working properly, if the power supply is connected to the mother board and also check the front panel switch is connected to the board
Jan 16, 2010 | Gigabyte GA-MA785GM-US2H Motherboard
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
Computer failure
well there is a power button on the back of your computer
make sure that this button is on
and make sure that the power cable is firmly connected and maybe u can try to change the power socket also
if nothing is working then its the front panel is not working anymore and needs to be replaced
if u have any warranty on the computer then contact the warranty ppl to change it for u
cheers
Sep 04, 2008 | Acer Aspire L100 PC Desktop
Power switch does not turn computer on
If the switch has a (O) and (I) on it ,the (I) should be pushed in.
Jan 10, 2008 | E-Machines eMachines Desktop PC
Northgate (STAX2517C2) PC Desktop Logo
238 people viewed this question
Top Northgate Computers & Internet Experts
Lee Eismann
Abhinandan  Patil
Abhinandan Patil
Are you a Northgate Computer and Internet Expert? Answer questions, earn points and help others
