Question about Toro Co M/R Blwr/Trmmr Rear Bag Kit
Toro Proline 400 blades fall out of engage
My Toro Proline mower randomly drops out of the engage position. This has an electric clutch (new one year ago) and I have checked all wires for a short. Anyone have any ideas why this is happening?
  • Anonymous Mar 29, 2014
    bague de direction
    ou trouver la bague de direction ref 54-2630
    Champion:
  • 205 Answers
If your unit desengages have the clutch gap checked. also you should check for shorts in your safty wiring. the other would be a bad switch. finely your under warranty this my be warranted.take it to a toro dealer or call one to make sure
Posted on Oct 13, 2009
Blades won't engage on my toro ss 5000 zero turn mower
for any ride on machine that the blades don't engage id start at looking at occupancy seat switch , these are most times the culprits then if that's ok I move on to the actual engage switch and then on to clutch as last element
don't forget that past 2013 mfg machines operator must be in seat and weight over 80 lbs , the clutch pedal must be depressed and transmission not in reverse to engage the blades on a consumer grade lawn tractor (thank the CSB for that )
Aug 27, 2015 | Toro Garden
Toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Apr 10, 2012 | Toro 52" Cut Wide Area Walk Behind Lawn...
Hi have a Toro wheelhorse 212-6. new to us. wont cut.
Yes, there is a switch on the dash. It operates an electric PTO or clutch for the mower blades. That is how most lawn tractors work. Of course , yours could be different, but if it is, It still has a clutch somewhere and a lever to engage the blades. Most of the electric ones are controlled by safety switches, One being in the seat, if you are not in the seat, it will not connect, if you get out of the seat with it running, the engine will cut off. Sometimes one is on the mowing deck, it will not connect if the deck is up. If you cannot get the PTO to work, it could be shot. (Rare) You can hear it go when it starts, check it out, hope this helps.
Jun 06, 2010 | Garden
Briggs & Stratton wiring, can it handle an electric clutch?
You might have a capacitor in line with the clutch motor that requires feed from the engine to allow the clutch to engage. I think the red lead is charging current to the battery plus post. Get yourself a 270962 repair manual and it will show you how to wire these things.
Apr 13, 2010 | Garden
Toro 216 triple mower . the electric clutch will not switch off leaving the blades in drive all the time . can the clutch be striped down and repaired
the switch where the blades are engaged try to unplug from the back of the switch if the blades are still engaged after you unplug the switch then the clutch is at fault. If the blades disengage and shut off after you unplug the switch then all you need is the switch!! The clutch can be repaired but the parts are very hard to get if you can even find them!
Aug 26, 2009 | Garden
White smoke and blade won't engage
Sounds like a low compression problem. The piston rings have most likely failed and oil is seeping past them and burning, thus the white smoke. An engine needs three things to run...Spark, Compression, and Fuel. Just take the mower back as it is still probably under warranty. Mike. Rate 100% please.
Jul 01, 2009 | Toro Lawn Mower With Toro Power Tools
Toro mower is blowing 30 amp fuse
Yes it is. It is an electro-magnetic device that 'grabs' your blade pulley, that normally free wheels, to turn your blades when there's power to it. Dwain
May 24, 2009 | Oregon Scientific Electric PTO Clutch for...
Toro Co M/R Blwr/Trmmr Rear Bag Kit Logo
476 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
