Question about Nu Mark Numark Cdx Table Top CD Player CD Player
Every time i want update firmware my numark cdx fail i try all speed of burning
4 Suggested Answers
  • 4 Answers
SOURCE: numark cdx
Have had a few issues with cds not reading very well, on intial spinup and random looping and skipping during playback. The CDX's weak link is the cheap CD drive used, and I found replacing the laser solved it for me.
The laser itself is a Sony unit, KSS-213C. I found one on Ebay for around £10 all inc, from a company called LittleDiode (http://stores.ebay.co.uk/LittleDiode). If you're handy with a screwdriver and a soldering iron, it's not too difficult to replace. During fitting, don't forget to desolder the link on the edge of the board that protects the unit during transit, or it won't work when you power up!
At £10, it's a lot cheaper than having Numark sell you a whole new CD drive for £100+!
Posted on Mar 27, 2008
  • 4 Answers
SOURCE: My Numark Cdx and Numark Cdn90 are frozen
Hi Mitchdias,
Have you tried downloading the most recent rom update for the CDN-90? All you need to do is download it from here http://www.numark.com/contentmgr/showdetails.php/id/1493/tt/5 , then burn the download to disc. Once that's done, put the disc into the player, switch the player off and wait 10 seconds, then switch it back on again. the player will read the disc and flash the ROM. this should reset the player for you. Before you ask, you can out the disc into either side of the player. Full instructions are given with the download.
Posted on Feb 15, 2009
SOURCE: Numark Axis 9's. . Problematic. Ahhhh!!!
Ok i have been having this problem for almost a year now. why am i still using axis9??? i dont know. I have been through 4 new different pairs of axis 9s. I keep sending them back, and they will reimburse me the money. ( not the full amount) I will then go back to guitar center and purchase a new pair only to have the same problem. iv tried everything from changing my cd burner, CDRs, burning speed, different computer, but still same problem. for a while i taught the CDR companies down graded the quality of there cds, but i was wrong. Its all NUMARK to blame. The other day i finally got scratch serato thinking my skipping problem would be over. to my surprise 45 min into my set skipping started. Next few songs my left deck would not even read the serato disc. It was embarrassing as people watched my ******** trying to figure out what the hell was going on. I had to cut my set short, and i blame NUMARK fully. Why is my portable cd player from the year 1998 plays better than there $300 piece of **** equipment. I now have 4 axis 9 that i am going to send back to Numark so i can get my money back, and use the cash to get some pioneers. I WILL NEVER USE NUMARK AGAIN. AND I WILL TELL AS MUCH PEOPLE AS I CAN TO NOT PURCHASE THERE PIECE OF **** PRODUCTS. THE BEST THING TO COME OUT OF NUMARK IS THE CUEING ON THE AXIS CD PLAYERS.
Posted on Apr 01, 2010
After playing for 10-15 mins. My song that I am playing starts to slow down and sounds muggy. Then it saids, " calibrating failed, check needle and record'. I have the NUMARK CDX
I'm not certain what type of drive system this deck has but it sounds like it could be a direct drive. In which case it could be that after 15 minutes some kind of semiconductor is getting hot and playing up, so it effects the speed. An examination of the components might reveal a very hot IC or transistor. You could even try to spray it while the device is running and playing up, with Servisol Freezer Spray. If it returns to normal once the suspect part is sprayed, you have a faulty part. You must only spray one suspect part at a time, not allowing the spray to go on other parts, or you will get the wrong result. And if it has no effect, you must allow it to warm up again, before testing another part with the spray.
Jan 12, 2014 | Numark CDX Turntable
I have a DVD duplicator 2057 and when I burn a cd, it won't play in the car, but the original works fine. Both discs are the same and I have tried 10 time and all failed. I even used DAO and TAO, still...
If you are troubleshooting a system or OS problem, you should not consider firmware updates until after exploring more typical troubleshooting steps like file system error checking and anti-virus scanning.
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this should schedule the task on restart then defragment your hard drive
hope this helps
Jan 30, 2011 | Computers & Internet
Sorry, this isn't a solution but I just wanted to mention that I just got an Axis 9 and it is not playing burned CDs either. And I see another problem reported on this site specifically called "my axis 9 wont play burnt cds". What in the heck, Numark? Are all the Axis 9's this way?
Jan 18, 2010 | Nu Mark AXIS 9
Numark HDX system needs upgrade: Insert upgrade cd?
You just need to type Numark Hdx in your search engine or on numark's website, and they have the download for the firmware update. Download and burn to disk. Turn on your deck holding the eject button until it ask for you to insert the disk you burned. Go thru the prompts and let it install firmware *NOTE DO NOT TURN OFF DECK* or you will ruin it.
Jun 12, 2009 | Numark HDX Turntable
Hi Mitchdias,
Jan 05, 2009 | Nu Mark Numark Cdx Table Top CD Player CD...
CDX FROZEN UP!?!?!?
Because the unit freezed half way through a firmware update then it will have to be re-flashed and also these players do have some servo problems,if you havent had it fixed you can send it to us.
Regards.
http://www.audiovisualservices.info/
Dec 01, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Numark cdx
have you checked the brake and start up settings they are the dials by the start and stop buttons it it is turned too far the platter will start up slow, you just trun to dial till you get the right start up speed you want
Jul 25, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Numark cdx
I'm sorry to tell you this, but my advice would be to buy a pair of Pioneer CDJ-800s or CDJ-1000s
I can't see the 800s costing you much more that what paid for the Numarks, and there's a reason why the Pioneers are used extensively in nightclubs, and the Numarks aren't.
Mar 20, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
CDX NOT RESPONDING
Sounds like the operating system has crashed somewhat.... Is it still operational enough to read a firmware update disc?
Jan 12, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Nu Mark Numark Cdx Table Top CD Player CD Player Logo
190 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
da surgen
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
