Question about Frigidaire Dryers
Frigidaire Dryer Drum Making Noise When Turning
Hi, I have a frigidaire electric dryer. Model FER231CAS2. It is an ordinary dryer. Nothing fancy. I've had it for 5 years now. When the drum turns it makes a cranking noise. I thought it was the belt at first. So I followed the instructions that I found here and was able to take the belt off and look at the pulley. they both look fine. Upon taking the drum out, I saw that there is a circular spring that is the diameter of the drum itself all the way in the back and this was broken in many places. I can't figure out what its called, nor where to order it. I'm in Toronto, Canada.
All help is appreciated.
  • 1,531 Answers
That big spring in the back of the drum is your heating element.the part number is 131553900.not sure where to get it up there but marcone appliance parts in st louis missouri might be able to help you out ther phone number is 1-800-482-6022.good luck with your dryer i hope this helps
Posted on Sep 19, 2009
My frigidaire fer231cas2 makes a horrible loud GRINDING noise after its been running for 10 or so mins
Hello friend, thank you for your post!
I see that you have changed multiple parts within your Frigidaire dryer due to a grinding noise. Since you have changed the bearing cup, felt, pulley, and belt I would recommend having a technician come out to diagnose your appliance to avoid any further unnecessary part purchases. You could be seeing an issue within the drum or motor. I hope this information is helpful. -Matt
Aug 26, 2014 | Frigidaire Dryers
My frigidaire fer231cas2 makes a horrible loud noise after its been running for 10 or so mins
There are rollers that the drum sits on. The roller surface or bearing can go bad causing the noise.
Drum makes loud banging noise.
Maybe the heat in your dryer over time has melted weak glue and loose components are hitting against the drum
Jan 16, 2012 | Frigidaire Electric Dryer
Make Frigidaire dryer model Gleq2152es1 is making a loud sqealing noise and the clothes getting hung in top of dryer.
mostly the noise your hearing is the drum running on the side of machine .the baering/bearings have collapsed in your drier . Most driers these days have the bearing encased in the outer drum and i mean molded to the outer drum . You cant replace them and the manufacturer doesn`t really want you to . Sorry about that = looks like a new drier for you .
Aug 13, 2011 | Frigidaire GLEQ2152ES Electric Dryer
No power
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
drt312
May 09, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire LEQ215EE1 dryer making thumping noise
Posssibly have a bad drum roller if mechanically inclined you can do this yourself but you need to take the drum out to do this
Nov 15, 2009 | Dryers
Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
Aug 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Drum making intermittent sqeaky noise for 3-4 minutes then stops
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
Frigidaire LEQ332DSO Squealing Noise
sounds like rear bearing is dry you will need to remove drum to get to it pop clips in top and raise 2 phillips scews 1 in each side remove front remove belt from drum lift drum up in rear and remove ck to make sure plastic bearing is not worn down to metal bracket if it is it will need to be replaced
Jul 07, 2008 | Frigidaire GLER341A Electric Dryer
Dryers Logo
220 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
