Question about Garden
I have a farris riding lawnmower that wouldnt start. i changed the starter and cylinoid and a relay switch and it just clicks can you help
  • 8,404 Answers
Is your battery up to the task? fully charged? Ignition switch is in good condition? Are you properly lined up with the fly wheel? Have the correct gear on your starter?
Just a few things I would check up front.
Will the starter run if you take it off and put it on the floor? (Remember, you need two wires to make it run off the mower.)
Posted on Sep 07, 2009
2003 Chevy Silverado 2500 HD wouldnt start acted like starter just clicking. Jump started off cylinoid now all lights are on brake abs check engine service 4wd. Also won't change gears or go into 4wd.
Clicking at the starter is usually caused by a weak battery or cables . Why didn't you jump at the battery ? Did you hook it up right , positive to positive ? You messed something up ! Better take it to the dealer !
Apr 01, 2015 | Chevrolet Silverado 2500 Cars & Trucks
How to check lock-out switchs on riding lawnmower
try jumping it with your car/battery. If that doesnt work, try jumping directly to the starter. If that works, it would be your starter solenoid.
Jun 17, 2014 | Craftsman 20 Hp 42" Deck Lawn Tractor
Doesn't turn over or start
Five most likely causes 1. dead battery 2. faulty starter cylinoid 3. faulty ignition switch 4.loose connection at any of the points5 faulty starter relay. the battery can be removed and taken to most any parts store and checked. likewise with the starter/cylinoid. checking for loose or bad connections is pretty self explanatory. move from connection to connection and check for loose connections or corrosion. once you know your battery and starter are in working order (you should only be into this project for your time at this point) you can check your ignition switch and starter relays with a voltmeter and/or test light to identify where the current is stopping. hope this helps good luck!
Oct 15, 2013 | Mitsubishi Diamante Cars & Trucks
MY RIDING LAWNMOWER STARTER JUST CLICKS.I BOUGHT A NEW STARTER AND IT DOES THE SAME THING.
didnt specify type of rider but can b 1 of a few different problems-the clicking is the relay to the starter-- 1st check that motor turns if motor bound or seized starter wont turn it over -check that starter gear and flywheel mesh correctly if not might have to shim or adjust ,next check battery {full charge}and connections ,wiring ,and the fuses for corrosion and or damage.check the safety switches next the seat ,brake,and blade on, these switches will not let motor start if damaged ,activated,or bad wire.
Sep 20, 2012 | Ariens Garden
2009 sportster relay switch clicking
Check your battery connections and make sure they are tight where the positive cable attatches to the starter and the negative cable attatches to ground. Sportsters are notorius for this type of problem when the cables are loose.
Jun 28, 2012 | 2009 Harley Davidson XL 1200C Sportster...
How can I use a jump wire on the starter cylinoid to start my mower?
the safety switches go bad more like the one for the brake/clutch pedal try and jump it with a paper clip to test it
Apr 22, 2012 | Craftsman Garden
94 dodge intrepid wont start
clicking in the fusebox? And the starter could be because you need a new one. or a rebuilt. The clicking is your starter cylinoid.
Aug 26, 2009 | 1994 Dodge Intrepid
Ride on lawnmower isnt starting.
You may have a bad starter - the solinoid is "clicking" but not engaging. Remove the starter and clean it up and connect it to 12 volts to check if can turn. If not then buy a new starter and replace it out.
Aug 03, 2009 | Garden
Jeep wont start
Under the Hood there is a Fuse Relay box that has the Starter Relay and Fuel Pump Relay in it. Replace these and see if it will not Start. The Relays Just cost a Couple of Bucks and Could head off this Problem for you. Please Rate my Response, I need all the Help That I can Get! Thanks!
Jan 27, 2009 | 1993 Jeep Grand Cherokee
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
