Question about Oster 3212SNB Food Processor
Reset/Breaker overload switch?
I have an Oster 3212 Food Processor and I recently overloaded the motor by trying to chop something too large. The motor hung up for a second and now won't work even after leaving for a few days. Is there some kind of overload switch I can reset?
  • 15 Answers
SOURCE: I need a replacement bowl for the Oster 3212 Food Processor
I contacted the manufacturer and bought the bowl. This is frustrating as I had contacted their authorized service center and was told the bowl was unavailable.
Posted on Jun 25, 2009
0 characters
1 Points
How can I test the motor relay on a Magimix food processor?
Overloading may have caused a thermal protector buried in the motor windings to open in which case the motor will have to be replaced.
Jun 04, 2016 | Magimix 4100 Cuisine Systeme 1268 Cups...
My Oster 3212 food processor will not turn on.
You have to make sure that both the bowl and the cover are locked into place. Sometimes if you wiggle it a bit, it will go into the right spot. Make sure that the outlet you are using works.
May 22, 2014 | Oster 3212SNB Food Processor
My kitchenaid food processor won't work
Does the actuator push down far enough to catch the button at the bottom? I repaired one simply by adding a vinyl screw cover to the top of the button so it was tall enough to be reached by the actuator.
Dec 20, 2011 | KitchenAid Food Processors
On switch not working on my oster 3322 food processor
Feb 19, 2011 | Oster 3212SNB Food Processor
The robot coupe will stop working periodically during use. The reset button on the bottom pops out after it has been used for a short while. I run a kitchen and it can be very frustrating trying to get...
It is overheating, probably because it is being overworked. Some common problems are overloading the bowl, or forcing too much food into the hopper on top. Once it overheats, it will kick out again rather quickly the next time unless the motor has time to cool. If you are shredding cheese, slow down on the amount of cheese forced into the blade. If you are trying to mix heavy dough you are probably overloading the bowl as well. This machine can't handle over a pound of pizza dough without overheating. The reset button is there to keep from burning the motor out. If you continue to reset and force feed the machine, it will burn the motor out. Good luck, hope this helps.
Sep 11, 2010 | Robot Coupe R2U Ultra Food Processor
The motor stopped working i unplugged and replugged into a number of outlets...nothing happens is this a burnt out motor or could it be something simple?
Hi there, I just had the same problem and then found an on-line manual that says this:
An automatic, temperature-
controlled circuit breaker in
the motor ensures complete
protection against motor burnout.
If the processor runs for an
exceptionally long time when
chopping, mixing or kneading
a thick or heavy mixture in
successive batches, the motor
may overheat. If this happens,
the processor will stop. Turn it
off and wait for the motor to cool
off before proceeding. It will
usually cool off within 10 minutes.
In extreme cases, it could take
an hour.
Yayyy! Problem solved (I hope)!
Hope that helps you...
Nov 02, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
Sep 12, 2009 | Cuisinart Food Processors
Jun 24, 2009 | Oster 3212SNB Food Processor
Can you slice almonds on the cuisinart dfp 3 if so how?
It is very difficult, but the machine is capable of it. Use the chopping/mixing blade (S-shaped blade). You would place a small amount - about a small handful - in the workbowl, and pulse the almonds only for about 2 seconds. Even if you want to eventually chop a large quantity, only do about a small handful at a time. It is so difficult, because the almonds will be completely pulverized if you leave it on for even 3-4 seconds. Many people who try chopping almonds, nuts, etc in a food processor discontinue the practice b/c it is so easy to overchop them into dust.
Apr 19, 2009 | Cuisinart DFP-3 Handy Prep 3 Cups Food...
It just stopped working
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
Your processor should now turn on.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
-Tha Mp3 Doctor (also loves Cuisinart)
Oct 29, 2007 | Cuisinart DLC-10S Pro Classic Food...
Oster 3212SNB Food Processor Logo
88 people viewed this question
Top Oster Food Processors Experts
John Miller
ray gallant
Are you an Oster Food Processor Expert? Answer questions, earn points and help others
