Question about Viking VGIC305-4B Gas Kitchen Range
Right rear burner is only sparking intermitently or not at all. Just started. Stove is 5 years old.
    Sergeant:
    Champion:
  • 255 Answers
Clean aera with sand paper, check that wire is frimly connected.
Posted on Sep 07, 2009
My 10 year old whirlpool super capacity 456's right front control knob started to burn with flames shooting out. Disconnected plug from wall and have been using lighter to start burners. Any idea as
there's a wiring harness with 4 or sometimes 5 switches depending on the model you have that slides onto the valve so when you turn the knob that burner will light,the switch most likely shorted out.if this is a regular stove with an oven and burners on top look down at the bottom,under the oven door you'll see a draw,open the draw and look on the frame not on the draw on the frame and you'll find a tag with the model and serial number on it,send the model number and i can look up your model.
Nov 20, 2011 | Kitchen Ranges
I have a Wolf gourmet 30" stove. it's about 10
Interesting, I'm looking for a solution to a similar issue. Our new (7 month old) 30'' Wolf Range has this issue. When both front burners are light, the back burner's electronic starter begins to click, but only when you put a pan on the front left burner. I believe the iron/steel in the pan is causing a magnetic field thats starting the rear burner to go off.. just don't know.. will report back after the repair person comes.
Jan 22, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
JGC8536
If the front left also does not light normally, my best guess would be that the wires for the front left and right rear are crossed and the insulation may have fried. Besides that possibility, I have no clue.
Feb 14, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
Electric igniters dont shut off
Remember to turn the control knob past the "LITE" setting once the burner fires.
If that is not the issue you have one or more defective spark switches.
Each valve has its own switch wired in series with the others.
Mar 12, 2009 | Wolf Manufacturing Gas Kitchen Range
Ignition sparking on its own with GE mongram gas stove top.
the sparking is one of the switches under the knobs shorted you may be able to open the top and take a switch off 1 at a time and you can figure out what one is shorted.or you can just change all of them.
to stop this you may be able to just unplug the cooktop from under the top.if you unplug the cooktop you should be able to light the burners with a match.
Nov 14, 2008 | Cooktops
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ignition sparking repeatedly
I have a Creda gas stove ,yesterday some water boiled over. I have a continuous spark ever since and the stove is not even on. Is there any way to reslove this without calling a repair person?
May 01, 2008 | Cooktops
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Jul 18, 2007 | GE Profile JGSP48 Gas Kitchen Range
Viking VGIC305-4B Gas Kitchen Range Logo
190 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
